Steven Marks secret
Started by otto, October 07, 2009, 12:26:21 AM
forest
Steven Mark :
"Now about the DC output with AC signal.
There is a book about Nicola Tesla "The Man who Had lightning in his hand".
I suggest that you find a copy of that book and read it.
In that book it is related that Tesla states that you can have all kinds of electrons flowing through a wire traveling in different directions relating only to their potential power source.
He even said that you could have different electron flows through a single wire completely separate from each other.
I tried it and he is right!"
Think about implications for interconnected resonant systems.
teslaalset
wattsup
Quote from: forest on December 10, 2009, 09:02:05 AM
Steven Mark :
An example of this is the modern home intercom system. You just plug each station into a separate wall outlet and the com signal travels through the AC line and is captured by the other stations.
wattsup
Quote from: Gobaga on December 09, 2009, 10:03:56 AM
In regards to the Ozone patent and associated circuit:
1) When the cap discharges through the primary coil (M), are the coils for the motor (D and F) are also connected to the power supply?
2) If so, this switches the HV from the capacitor (L) over the low voltage from the power supply.
3) What does this do?
1) Yes the negative of the complete circuit goes through the motor coil. But you have to look at it like short noshort.
Notice that Telsa always used an armature in his commutator motors when he knew the circuit will be pulsing thus having off states, the energy held in the armature is required to keep the rotor turning during this off state. So he is taking the energy even in the armature of his device to do that while the feed source is disrupted and this energy is also used to keep the commutator moving while also turning a fan to move air through the ozone chamber. That clears you for the rest of the energy play.
It's like he was listening to Mozart when he made this device. The device would work like a symphony with all the parts playing their roles at the same time, reverse left swing, reverse right swing.
2) & 3) Yes part of the device function is to put back energy into the source which is usually a battery setup.
Capacitors discharge when connected, inductors discharge when disconnected. Resonance is a function of both these actions happening in the highest sync possible given their two parameters. Proof, change the capacitor value and your resonance frequency will change. Same goes for the inductor or coil. So everything is relative to how deep your inductor can take a charge when connected to release it into the circuit and how many mF the capacitor has to take all the release in when it passes the low resistance primary working circuit. Now what actually happens is a continuous reversing of polarity over the primary. So the number of segments on the commutator had to be matched to the expected cycles of the motor rpm to produce the required pulsing frequency of the circuit and the components were chosen for their specific values given these set parameters. And yes, in a subset device he has a control for the motor coil to vary the spark rate.
In this case Tesla decided to use a short primary on a long secondary to produce high voltage discharges (today we use corona discharge) that crack the oxygen bonds releasing single atoms that then bond to other oxygen atoms to produce ozone at a very economical level because a major part of the used energy is always returned to the source battery.
That's the way Tesla did things at that time. His patents go much deeper then the device itself. He knew that most people including the guys at the patent office will look at these patents and just worry about the nuts and bolts and not realize the true underpinnings that make it work. lol
This is from a long time forum member named @Erfinder;
http://www.overunity.com/index.php?topic=3972.msg79545#msg79545
You may want to look up his posts on this forum. Me I am just a low leveler.
But, I have learned that there is a big difference between regular resonance and what I would call "full play resonance". You can take any coil and any capacitor and you will eventually find the resonance frequency. But big deal, this means nothing. Take a 1 henry coil and take a 1 picofarad capacitor and you will find the resonance. Take a 1 mH coil and a 1 farad capacitor and you will again find the resonance. But in both cases the exchanged energy is totally insignificant. Now as soon as you match your coil value and your cap value so each will pitch and catch the total energy of the other, then you find your resonance, then you will see what is the difference between a tapping and a hammering action. lol
