Pauls Device; a damn shame he regrets revealing it.
Started by Zeremor, March 08, 2006, 11:42:32 PM
Omnibus
Friction has nothing to do with the production of excess energy in SMOT. The excess energy produced is the difference between the potential energy at the output of the device and the potential energy at the input of the device. This difference is acieved spontaneously, by the magnetic field, without external energy input. The experimenter doesn't expend energy for the obtainment of the said difference.
Nastrand2000
actually, the potential energy of the ball is less at the top of the ramp. Its gravitational potential has increased, yet its magnetic potential has decreased. The magnetic potential is expodentialy stronger then the gravitational potential in this partical case, but as the ball falls away its gravitational potential vs its magnetic potential is less then equall. giving is a c.o.p of less then 1.....this is why the ball will not roll around to its starting place.
Omnibus
The energy spent by the experimenter to lift the ball from its initial position (see definition of ?initial position? in my previous posts) to the level where the input of the device is is exactly equal to the energy recovered when the ball is returned from the level where the input of the device is back to the initial position. In this way, that part of the loop now is taken care of and all the energy the experimenter has spent is fully recovered.
In addition, to close the overall loop, there is one more segment ? lifting of the ball up the ramp from the level where the input to the device is and then falling of the ball off the end of the ramp to the level where the input to the device is.
For the lifting of the ball up the ramp the experimenter spends no work. This lifting is spontaneous. Upon this lifting kinetic energy and gravitational potential energy are spontaneously imparted to the ball. Also, magnetic energy, which is exponentially stronger than gravitational energy, is decreased.
Now, when under the action of gravity the ball spontaneously falls off the top of the ramp to the level where the input is, the following happens:
1) The ball spontaneously restores the same greater magnetic potential it had when at the input to the device. Therefore, there was no gain or loss magnetic wise in this segment.
and in addition
2) The ball spontaneously produces excess energy due to the height difference it had acquired spontaneously when moving up the ramp (never mind the kinetic energy it also acquired).
Nastrand2000
lets have the ball run up 10 consecutive ramps in a linear fashion...each ramp being slightly higher then it starting point....its should place the ball signifigantly higher then the starting point....then the ball can roll around to the starting point and start the process over defeating the frictional loss....this does not happen...i have created this scenario....the ball wont start again....dont get me wrong...i believe there is "free energy" out there....this just is is not the way to acheive it
Omnibus
That's a second step. Before doing that, convince yourself that a single SMOT produces excess energy periodically.
