Can someone identify this thing?
Started by 3decimal14, October 11, 2009, 01:03:38 PM
Spider
An electromagnetic black hole made of metamaterials
http://arxiv.org/abs/0910.2159
Traditionally, a black hole is a region of space with huge gravitational field in the means of general relativity, which absorbs everything hitting it including the light. In general relativity, the presence of matter-energy densities results in the motion of matter propagating in a curved spacetime1, which is similar to the electromagnetic-wave propagation in a curved space and in an inhomogeneous metamaterial2. Hence one can simulate the black hole using electromagnetic fields and metamaterials. In a recent theoretical work, an optical black hole has been proposed based on metamaterials, in which the numerical simulations showed a highly efficient light absorption3. Here we report the first experimental demonstration of electromagnetic black hole in the microwave frequencies. The proposed black hole is composed of non-resonant and resonant metamaterial structures, which can absorb electromagnetic waves efficiently coming from all directions due to the local control of electromagnetic fields. Hence the electromagnetic black hole could be used as the thermal emitting source and to harvest the solar light.
http://arxiv.org/pdf/0910.2159v1
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
kurtnorway
Found this oscillator in an old GPS navigator.
Is it possible to make a variable frequence oscillator out of this, anyone with some radio knowledge maybe kan answere this ?
kn
sparks
   Crystal radios are free energy devices.  Need a scaleup and away we go.  Keely Tesla and most musicians understand resonance.  You can store very feeble inputs over a time span in a resonant system.  So if you can transduce electomagnetic wave energy or if you prefer photons into emf and then produce longitudinal waves you can vibrate most anything apart or move it in most any direction.  The aether is filled to bursting with electromagnetic waves.  Observe them store them release them.  People in the way back machine carved solid pieces of granite to accurate planes and angles that our state of the art laser technology has a hard time just measuring never mind fabricating.  I don't see some slave inside a granite box working the corners down with a bronze chisel to nanometer precision.  And why would a pyramid have an electolysis tank and a resonant chamber connected to a third chamber in which this box was placed.  Say they want to disintegrate something.  Maybe the Kings corpse (or any number of corpses for that matter) heres what you do.  You fill the electrolysis unit with salt water.  Then you turn on the juice from maybe a copper acid battery bank.  The hydrogen and oxygen accumulate in this column.  Then you spark it.  The shock wave enters the resonant cavity where it is modified into the proper frequency to set the big resonator over the kings chamber into action.  The granite box is a nice combination of crystals and various radioactive isotopes.  Sound energy is absorbed by the box from the massive mechanical resonator above it and the box now converts sound energy into electrical energy via the piezo effect. The Uranium isotopes are now stimulated into decay mode and the neutrons start to do their thing on the dehydrated corpse.  It lights it on fire first then it turns it into plasma and the plasma responds to the magnetic field lines passing through the chamber.  Out the little tunnels aligned with the magnetic field lines of the Earth flys the pharoh in this weird green aurora borealis glow.  That's enough to scare any poor working Joe into believing the Pharoh is heading for the big dipper.  That poor bastard is not going to be late for work the next day even if the priests of the temple don't pay him.  That's what happens when a technologically advanced society dumbs down.
Pretty soon guys like Tesla and Keely and Leedskalin start to appear as in tune with the supernatural when all they did was use their minds to do other things than chase ass and get high.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
Can you say 'Zardoz'?
@all and anybody that has no clue what has happened,
Ed leedskalnin had variable capacitors in a wooden box. Had an a.m. radio in a steel box. Had cables running under the ground across the castle. 'This place is a mess. Lets make things right!' They exclaimed and newly educated owners cleaned up the park. They hung the capacitors on the wall by the generator with care, they set the radio by his bed for his listening pleasure, and they pulled up those nasty old wires sticking out the ground to keep the visitor from tripping.  Ed has to be turning in his grave... Go ahead and hold your religious symbols dearly, close to your bossom of ignorance. The 'Star of David' is a 2 chord heterodyning resonant model. The Swatztica is a 4 coil, 2 phase rotorless Tesla configuration. The Chinese Ying and Yang is a sine wave in a resonant spherical chamber. Magnet frequencies can align DNA into their pristine state. Today we have groups aligned with the Star or the Swatztica. The Ying is seen as an emotional balance. True, but a small view.  Magents are worn as jewelry and believed to cure and seen as quackery. The Ancients are seen as mystics. Today the race of humans is nothing more than a bad product of eons of 'Whisper down the lane'. See what all the great teachers are up against? The flood and the destruction of Sodom and Gomorah were atempts to stem the tide of ingorance. And in the reference I do mean pathetic long term ignorance. Quetzalcoatl is coming back to stop the bullshit once and again for all. I guess that gives new meaning to 'Every eye shall see and every knee shall bow'. Just maybe everybody will see the intellectual primary goal instead of the ignorantly primal goal at the same time?
@Sparks, Thanks.
--gk. Round and round it goes.
Quote from: sparks on October 25, 2009, 11:37:01 PM
stprue
@Gk
I didn't get a chance to make that video yet but I did mess around a little last night before bed.  After grounding my TPU I could get about 22v either AC or DC with an input of 10v at 5KHz.  I'm still pretty sure that I'm not hooking it up right but at least I'm getting something.  What were your voltage results on the TPU in the last video you posted?  Was it self running for a while?
