1-phase to 3-phase inverter
Started by rkahler, October 15, 2009, 08:14:32 AM
MasterPlaster
PhiScience
Hi rkahler,
  I have been using a static converter on an air compressor and a Bridgeport mill for years now and it works just fine. I got it from McMaster-Carr, it’s on the bottom of this catalog page.
http://www.mcmaster.com/#catalog/115/921
Or you can get one off of ebay they also sell plans.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=phase+converters++&_sacat=See-All-Categories
The function of science is to make observations and measurements and to find correlations between the observed facts.
d3adp00l
dude just go on ebay,
http://cgi.ebay.com/1-HP-115V-IN-230-3-PHASE-OUT-VFD-FREQUENCY-DRIVE-NEW_W0QQitemZ360113575521QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item53d8711661
VFD drives can take 1 phase and make 3 phase, because vfds take ac turn it into dc, and then it makes 3 phase using 6 igbt fets. It switches the dc back and forth in three different phases.
History is full of people who out of fear,
Or ignorance, or lust for power have
destroyed knowledge of immeasurable
value which truly belongs to us all.
WE must not let it happen again.
-Carl Sagan
rkahler
Thanks, but I need at least 25 HP.
the_big_m_in_ok
Quote from: rkahler on October 15, 2009, 08:14:32 AM
I need inverter with 1-phase input and 3-phase output.
Can somebody make a suggestion ?
I tried Google, but I'm lost in all high tech datasheets.
http://www.google.com/advanced_patent_search  or,
http://www.pat2pdf.org
Patent #5,388,031
As a modification, this one has to be turned around the opposite way, but it would be simple.
But, as a concept, would it work as you want it to?  Wiring a transformer to give 2 phases from one signal input can be done, but the ground leg is just 0 volts---no phase to it, right?
I occurs to me that using only the hot side of 3 phases would give you one phase from three.
If you want the total output of the generator, a phase shifter to align the three phases from 120 degrees offset to one single phase would also work.
--Lee
