free power
Started by freepow, October 21, 2009, 02:21:41 AM
hartiberlin
Hi,
you could replace your wire with an electret foil where alufoil is put on.
The high voltage electret will pull in free electrons from the air which will
charge up the alufoil.
The bigger the area of the foils, the better.
Regards, Stefan.
the_big_m_in_ok
freepow said:
if its radio waves, why would it be illegall ???
@all
My question is, theoretically:
Would a long wire a ways from a transmitter actually affect the tower and transmitter at that distance?  The same for 50/60 Hz municipal mains lines?
Are the foreign Gov't(s) just being hard-nosed about the technical independence of some tinkerers or is there a valid reason; for example, people trying to act like stealing power when they wrap a wire around a power line by using a long wire instead?
Using coils to generate additional power by CEMF/BEMF would leave them with no logical argument, yes?
--Lee
onthecuttingedge2005
Quote from: freepow on October 21, 2009, 06:34:15 AM
:)Thanks gyula, But i have only been testing this for very short time, but tonight is the first night that the voltage is reading almost as much as the day time reading ! 5 and 1/2 volts, and the weather is the same as day before, do you think its still radio waves ???
I know humidity can change the way radio waves propagate through air, like in your case, if you have a weather lab try to take a reading of the humidity and other factors.
you also may want to email the FCC to see if there are issues, you might also get some suspicion from your local power company from all this as well. whether it actually factors into the equation or not.
Quote from: the_big_m_in_ok on October 21, 2009, 10:23:28 PM
freepow said:@all
--Lee
EMF impedance is infinite but at greater distances the impedance diminishes to the point where it would probably not effect radiation lobing to much if anything noticeable at all at the transmitter. unless of course the transmitter is in your back yard. that would not only be free lunch but a few mentally challenge children may spring up from time to time in ones genome. lol
the_big_m_in_ok
onthecuttingedge2005 said:
...unless of course the transmitter is in your back yard. that would not only be free lunch but a few mentally challenge children may spring up from time to time in ones genome. lol
Yeah, I agree.  Most telecommunications frequencies and RADAR are actually microwaves.  I've read that the Zazlon("Shield") RADAR system on the Russian Mig-25 Foxbat can roast a rabbit, from the inside out, in a distant field 500 paces or more away.
So, it might be you're right.  That type of radiation can easily damage the body; maybe the chromosomes and genes as well.
--Lee
