BWJT
Started by kooler, September 11, 2010, 11:25:22 AM
kooler
well..
i found this in the 1-100 TransistorCircuits.pdf its on page 25..
Mk1
kooler
wow..
that is a small one.. be kool if we could build Exciter's that small..
haha..
robbie
Mk1
@kooler
I had i idea , you Hartley circuit works from barely nothing , maybe it could run on a crystal radio set .
Now imagine the crystal radio set tuned to the Hartley circuit , feed back loop no wire ...
Obviously the crystal set may need to be tuned on a real radio station , but you could make more then one receiver and get more current .
Mark
http://www.youtube.com/user/Lidmotor#p/f/12/gcui0K7JZXA
kooler
Quote from: Mk1 on April 07, 2011, 05:11:56 PM
@kooler
Mark
run this circuit thru air i noticed it is very lot of lost..
but with certain high tension transformers.. i have got 1026 volts with only 1.1 volts input at 160 microamps..
of course it is very low current.. i can only see that voltage with a scope.. but it will lite a couple neon bulbs up..
but no cfl.. but it does seem to charge and revitalize batterys alot better than some other devices we have built in the past..
if you want i will make a small schematic of my better setup that is similar to the hartley circuit.. that will run some trigger coils and diodeless flybacks.. and handmade transformers..
i been mostly working on what i discovered back in dec. 29. 2009.. when i have the spare time.. !
with all the problems i have been having the past and current year.. i been trying to spend most of my time with my kid and wife..
but things are looking up.. and its all because of b vitamins and hydrogen peroxide..h202 inhaling a mist is a must for everybody..
once i start to feel better i will do more videos on some stuff.. i been sleeping 12 hours just so i can work a full 8 hour day..
but i will start doing more soon i hope.. if not i will see you on the other side..
keep up the good work ..
robbie
