Don Smith's Device #9
Started by Xaero_Vincent, October 27, 2009, 08:04:19 PM
turbo
I have tried this with rotating Stainless Steel scissor like blades long time ago.
I tried stationary coils/stationary magnets/rotating disk setups,
I also tried stationary coils/stationary disk/rotating magnets setups,
And stationary disk/stationary magnets/rotating coils setups.
All without luck and as a result i am convinced the magnetic field is a property of space and has no connection to the magnet other then the effect that is percieved.
Paul-r if you do find something intresting,i still have hundreds of old 3.5 alswell as a lot of old hard drives too.
I would be happy to crush them up to try something new.
Marco.
kukulcangod
Hi All
             Probably by the time you commented on this device you didn't know about the A videos of Don L smith on youtube, but I do recall in one of this he said "people had a problem making this and I have to tell them how, they are making them in Russia now" this quote is not verbatim but you can watch the video and confirm the idea behind it, thing is, he was an engineer and way beyond even tesla at least technology wise, he assumes everyone trying to build this devices knows the simple basics of engineering for he is used to it!... In reality we are a bunch of dummies overseing this facts, I do have some engineering experience, not to say it is our fault , he said he is not saying everything but you can see in his eyes the benevolent profesor that he is, just trying to make us think on our own,I believe he was just trying to tell us that: study the basics and you will tune up this machine just right for it needs to be in resonance.Variable speed controllers and so forth sound just right from that point of view, -easy?- not even for the intuitive mind!, otherwise we would've have this machine already... One thing I do know due to my experimenting, even the wrong type of capacitors will set you up for failure, some retain this hight frequency electricity some don't, I know because I pulsed several types of capacitors, and batteries, sounds complicated? basically I just shorted out a capacitor and batteries charging circuit!-manually-but if I didn't do it just right, nothing would show up on the multimeter! John Bedini has a video were he shows 2 types of electricity the yellow one and the most intriguing one , also mentioned by tesla and described as a "gas",etc, that can't be easily measured: the blue spark energy...this last one killed almost instantly by the yellow one, see? see the predicament? we have to be faster than this forms of energy! Bedini figured out how to separate both of them! I've seen both sparks while at it,The right capacitor and battery able to retain this tricky blue spark will light up an LED but a multimeter will give you no reliable readings and viceversa, our instruments  are not suit up for the task but you can observe the physical effects somehow, it lights up brightly for and instant then again it is just from one manual pulse! I thing Smith-obvioulsy- found the way to make this pulse continuous. I did used a radio "cheap"(you can't find sh... over there this days), excuse me radio shack 12v 7amh battery to reach 150,200 volts in a recharcheable disposable camera cap, I know many would say," Ho it is just a memory effect of this type of cap" But I don't think so, ok ok go to the forum related to it, but see? you must thing "multidemensionally" everything is related...Then again it begs the question, where is he now? what hapened to all of this great machines ? Where are the fabulous applications of this technology?, Do you know what I would do if all of this were practical and the world wouldn't believe me?, which I think is the case.... I would make my money and dissapear in brasil living in my own supersecret facility , why would I save a world that don't want to be saved?
Yes just like Tesla and Marconi it's been said did that very same thing... But don't loose faith please, do it for all of the innocents whom don't know better...
Cheers
Caduceus
A couple of points I would bring up about don's device are 1. I believe Don used neodymium powder which you can by online and which has not been magnetized to cover his disk.
2. The thing to understand about magnets and their bloch walls is that when you place to magnets together in attraction mode the bloch walls of each magnet will MOVE to the center, the junction between the two magnets leaving one whole magnet North and the other whole magnet South! It's because the bloch walls can move in this way that the magnetic fields become stretched all the way into the center. Now if the magnets are not fully in contact then the bloch walls will move inward perhaps 80 or 90 percent of the way in. When you break this magnetic connection with a neodymium coated disk the bloch walls momentarily spring back to their centers. So, it's the moving block walls and the accompanying magnetic fields that cause an electrical current to be formed.
Since neodymium powder on the disk would cause a further attraction of the two facing magnets I have to assume Don's magnets were in repulsion mode which would push the two bloch walls to the outer edges of the facing magnets and the disk would then block the repulsion-even adding an attraction by the neodymium bringing the bloch walls back in toward the disk
Paul-R
johnnyfg
Quote from: allcanadian on October 31, 2009, 03:21:07 PM
The first question we should ask about the Smith machine is ---- Are the magnets in opposition or attraction as both conditions will produce a bloch wall between them?.
AC
http://www.freeenergyinventions.com/donsmith.html
Not the same device, but another of his (Don). In the picture "Useful Circuits From Nikolai Tesla", the one in the lower right corner. Look Carefully, you see that top and bottom windings are NOT turned the same way. Not sure if this is a typo and/or this is also something that is present in Don's devices.
Im trying to learn how to use "LTSpice IV" To learn how to tune these devices.
/Conny
