Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
sparks
  Tesla was the inventor of the tuned circuit..  Before that time the spark gap was employed to cause radiation of hf as the antennae was charged to one potential and the Earth the other.  The dielectric of the spark gap is surpassed at some point and causes an oscillating current which was very unpredictable as the capacitor discharges.  They knew a spark threw radiowaves but as GK mentioned it is very broadband.  Everything from subaudible to uv and above.  Tesla picked out a frequency and made it stand collect whatever you can invision in his resonant electrical circuits.  He pushed the envelope until the amount of current and voltage in the tuned circuit was powerful.  Like gigawatts powerful.  Then of course all that was needed was a tuned receiver that would pickout his oscillations from all the rest of the stuff flowing around.  A capacitor when it is charged develops a tremendous amount of tension within the capacitor itself.  The coluumb force squeezes the shit out of the electrolyte.  The sudden discharge of the capacitor causes the metals employed to be accelerated at great speed away from each other.  This produces mechanical vibrations of the medium that are longitudinal in nature.  The uv noise and heat emanating from the spark gap are all losses of course.  This is energy on the way out or radiating.  What I discovered quite by mistake is the thermal properties of a selfconfining plasma.  The more heat it gets  involved in its field the colder the temperature it radiates.  Blackholes are nothing to fuck around with.  We are all blinded by the light as it condenses into the dark.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
bw
Mr. Sparks.    All that helps me.  Thank you for explaining in language I understand.
sparks
@bw
     Thankyou for listening. :)
          Tesla was very agitated by people going off and stealing his inventions.  He believed in patent protection which is a lawyers scheme.  His early work with induction motors and transformers made him a fortune but it wasnt the money with Tesla it was the fame.  He has a new wave of notariaty.  To read Tesla you have to understand the terms of the times.  When he talks about his radiant energy collector he is talking about a photoelectric detector.  He did know how to create and manipulate plasma.  Plasma creates the medium through which light travels.  We see the light but since the plasma is selfcontained energetically we dont see the plasma construct.  The Sun is a magnetically selfconfined plasma.  It will not run out of hydrogen fuel that will stop the fusion process inside it.  That is not the way of things.  It will cease to radiate anything but gravity.  The heliopause will contract into a sphere probably not much larger than Earth.  The vacuum created by the contraction of the heliopause will not go unnoticed by the rest of the interstellar medium.  The contracted core will build itself a new condensation of the Universal plasma or life sustaining force.
Think Legacy
Spread the Love
giantkiller
Let me repeat something:
I have 2 NSTs at 6kv @ 38.5khz.
I have a 10kv power supply with a variac. I need to put 1 channel from my Keely sine controller into the HVpwrsp to produce the HV at the resonate frequency of my current Smith build.
I prefer to find the frequency of my primary or sedcondary by dialing a freq then snipping wire length to find a statice frequency from the NST. The first way is just easier and I can verify my spreadsheet calcs. This type of attempt produces things a whole lot faster.
So this is my next step. A spark gap is not needed if the frequency is bang on with the HV input. Square waves also replace a spark gap.
Mass, length, spacings, & turns... You get these correct with the right distances and you have a huge disturbance with 2 wires. In other words, aside from the signal input parameters one is creating the bell housing to ring at the correct note.
The HV sine controlled power supply willl let me test the performance of any windings of mass, length, spacings, & turns by frequency and voltage. Square waves only give an approximation because of the inherent harmonics. I want true ringing with no degrading noise.
I also realized this about the GK4. It had an iron core and square waves appearing and eclipsing at numerous angles. When the iron saturated then the eclipsing square waves were then absorbed no more, producing the ejecting waves of noise inward & outward. This would make the center most dangerous, uncontrolled unlike Rodin's coil.
--giantkiller.
innovation_station
this is a reason and only 1 reason i use feroite cores ...
to contain the darn thing ...  not make rf noise and run very high speed and safe with low voltage and they offer high returns
all my cool things can be marketed and abide with in fcc guide lines ...
w
and i need not worrie of makeing any holes...
if they are built properly ...  i do not like the term abient noise..   the earth has a charka just as you do ...   and they run on harmonics ...    you can see this in some of my REAL CLEAR SCOPE SHOTS
the earth speed is the fundemental freq ... a magnet is in tune with earth
your base charaka stone is ...  fundemental ... ie garnet .. smokey quartz  LOAD STONE..... et many orthers ..
ring it ...  do you want to walk on water ?
w815
