Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
0 Members and 50 Guests are viewing this topic.
NickZ
  @Gk:
  Great, glad you like it, I hope that anybody interested in the Vortex Theory will get something out of that.  I have not found that type of information anywhere else, and I think that it does relate to what we are trying to accomplish.
  The Energetic Forum is also currently discussing the St.Clair patents:
   http://professorelliot.com/wordpress/2009/08/who-is-john-quincy-st-clair/
  I also feel that a working vortex generator device will draw or pull in, or lead-out Aetheric energy from the immediate space around the energy producing device.
  There may also be a relation to the way instantanious space travel works.  Demodulation and relocation. Interesting stuff...  As some units can cause an effect generation in the local space-time factor.
  Anyways, back to the drawing board and work bench for me, hope I didn't bore anyone.
giantkiller
Everything has value.
If one takes 2 St.Clair circuits and stacks them one on top of one another then he has achieved the SM17 in a slighty different configuration. And only slightly.
NickZ
   Gk and all:
    It may not take two coils to accomplish this, as is being shown by another member of the forum. A spinning vortex already has a block wall in the center with a spiral on top and a reverse spiral below the center.  Spinning anything will cause a vortex,  and the power of the vortex is what powers all space and time. Time may not exist, but we have made it exist.
  Since all physical matter tends to reach an equilibrium with it's surroundings,  we must somehow continue to pulse a device in order for it to continue to generate an effect, without stopping. St.Clair calls this the negative spring constant. So, it appears that in order to get a positive voltage we must produce a negative spike, and the negative mass (or Aether) will respond netralizing itself with a positive spike, which we can harvest. If we repeat this action over and over, positive current is produced.
  There are many ways to skin a cat, (quote from Wattsup), as we have seen several SM devices that use different components, but all using a similar proof of concept. Since his first and simplest device can resonate using only a couple of coils, a magnet, and possibly a cap. The proof is in the pudin.
DreamThinkBuild
giantkiller
This if for Forest and Loner the most:
The SM17 is the only unit that drove a true load. The other units just slam an incandescent coil with high frequency. He gets a white light not a yellow light.
Let us move to the next step:
All but the SM17 have vertical control coils, the coils on the outside. These units have interleaved fields. Pulse the bifilar in the same direction and you get coupling. Pulse the bifilar opposing and you get Bloch wall. The non-SM17 units have interleaved fields. The SM17 has a Bloch wall all on one horizontal plane because of the large diameter parallel loops. See the difference?
--gk. I see patterns.
Thanks @DTB,
Quote from: DreamThinkBuild on May 31, 2010, 08:43:01 AM
That St.Clair Patent reminded me of the Anderson Institutes warped fields.
http://andersoninstitute.com/time-warped-fields.html
