Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
0 Members and 90 Guests are viewing this topic.
forest
Quote from: giantkiller on November 16, 2009, 04:26:28 PM
Thought I would bring this post over here for cohesion.
giantkiller
can you post a schematic when a push force is making positive only impulses of higher second harmonic of ringdown ? I'm not good at it. Does somebody have a scope shot of something I'm talking about ?
Seems that I saw somewhere a picture which may be correct but I'm not sure.
giantkiller
Otto showed the schematic of the negative pulse from a FET and coil.
Quote from: forest on November 17, 2009, 02:35:43 AM
giantkiller
giantkiller
Requirement #1
High 'Q'
Coil wire of quarter wave length of determined frequency.
Requirement #2
Air core
Requirement #3
Tx/Rx Multipli or divisionally lengths of Oscillator frequency.
Requirement #4
Ratio and position dependency on load. (Muy Importante!)
Requirement #5
Copper mass to match load.
Page 6 second pic
http://www.free-energy-devices.com/Smith.pdf
For bifilar tests to work there must a ratio other than 1:1. Don points this out.
Tesla coils have their primary at the bottom. Ever wonder why? Move it to the top and exceed the copper mass current handling of your design. Tesla coils are electrostatic by voltage. I had posted another pic of the orignal Smith PVC coil by Tesla. It clearly showed the primary in the middle. Smith on the other hand made it (tunable? NO!) ratiometrically adjustable. Pure genius of design. Do you want current or voltage? Voltage is a electron left had spin and current is the right hand spin.
The primary has 14 turns and the sensing has 7 turns. Isnt that quaint? Using Don's information we can get alot by knowing the frequency, count the turns and layers. A Helluva lot!
Page 46, 74.
Resonance is think and maintain highest of 'Q'. This excludes high current. The coil abruptly throws out a magnetic charge. The higher the Q the farther the field with the most energy hitting a secondary.This includes alot of free electrons surrounding the coil. They are brought into alignment and then let go returning to statis. That BEMF is our kick in this design. In resonance the driving pulse hits before 100% decline. One - oh - One.
The fractions are positional meaurements and distance ratios. Not electrical measurments. But these figures are usable in the estimations. One can also count the windings! What a blessing.
--giantkiller. Is this a test?
Peterae
At Last people are waking upto Don Smiths stuff.
If you havnt seen the latest videos released into the wild Watch them theres some tasty bits in them
Don_SmithInventors_Weekend_2001
Don_1998_Interview_and_workshop
I had to buy them but they are now appearing on the net
Peter
giantkiller
Glad to hear there are others. I posted this 2 years ago and got dragged away into my curiosity of other coils and processes. Got ADHD. I am easily distracted by sparkly technologies.  :o And have built way cool devices with extensive doco behind them. An engineer's dream!
I do pattern matching to the Nth degree. I know that bothers some. But! Apply Don Smith's descriptions to Hutchison's work! Piece of cake. And that matching up quiets alot of trolls and naysayers. That is why I don't have trouble with them. I just throw another card/example from the masters on the table.
Here is another gift:
QuoteOf all the examples and explanations posted by all, Don gives outright the answer, a deep peer into the goings on in a linear fashion. I have found his to be the most clear cut in language that is native to all of us.
And that is how this thread got its name. 'Nuff said.
Grumpy said
Quote'By Christmas'
and that schedule has not stopped. Thanks.
So following Don's diagrams I have bought similar parts. I have batches of like capacitors and have built chains and arrays to get the voltage and farads. I have an ignition coil with an automotive spark plug cable connecting the plug and iggy. The plug is mounted in an aluminum can with others layers of cans wrapped around that. I have an em wave ghost meter for field sensing. The iggy will be driven with an IRF840 and 12v. I have the copper core coil that produced the ringing that STPRUE was duplicating with other windings over it. Simliar to the Smith TPU in the previous post but 4" diam. I have an isolated scope for measurements. My 12v supply are parallel RV batteries. This starts the front end pulsing. I also have an HV neon drive module coming in, Just like Don had mentioned.
It is treat time: Don's device has a 120v ballast. We get to skip all that because now they sell 12v input neon drivers for gangster's license plates and running boards. These are cheap. Frequency is 30khz. Don said 35k. Right off the shelf.
The output stage will be played with after I get this input side done. I have a handful of microwave oven diodes also. My cap banks are rated at 12kv102uf and 1kv@1000uf.
My control primary is a full wave length division of the secondary at 1/4 wave length. I can put other primaries on at a moments notice. I need to add a sensing coil. Nothing cut in stone. Everything modular.
No special controllers or technology that is susceptable to outburts. Also I want to start with a small sized device. In this case: size doesn't matter.
So I start off with a 12vdc go thru all the middle stuff to create a 12v supply to charge a cell phone? Why? Because Don stated that the battery leads supply DC and that magnetic field is pulsed with the resonant discharge of the circuit to recharge the battery(like a Bedini motor, mechanical). That means this can be done with a rechargable 'AAA' battery. Just like IST said!
--giantkiller.
