sparks
      A simple transformer turns ratio speaks to angular velocity power flow.  Current in the primary lots of mass moving threw say 10 rotations or turns.  100 rotations in the secondary but with less mass moving through the 100 turns.  Net transfer of power 1to1.  Rotation of the Earth the primary with lots and lots of current moving through one turn very slowly.  Secondary tiny bit of current relative to the Earth but doing a hell of alot more rotations. Transfer of power 1to1 vaporizes the tpu you and most anything nearby.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
ramset
Looks like its time to learn
FINALY!! [Thanks felloes]
Chet
Thanks Grandma
giantkiller
Here is another pattern I've seen:
Air core coils, single layer winds, high electrostatic potential. Why? Extremely high 'Q'. Why? We use the electron in the wire to conduct to create a field outside the wire. The high 'Q' enables that field to extend way far out in space thereby grabbing more electrons and coordinating a mass magnetic moment.  ;D
The larger the coil diameter the few number of turns needed and shorter in height and space the windings to increase the 'Q'.
The SM17 uses 2 large coils and two large caps configured as an L.M.D. This must then be excited. Electrostatic.
Don Smith uses a charge circuit to fire a spark gap not into the coils as an initial drive but as feedback to the input of the coil. This is the first time I saw this. I got his book 'An answer to America's energy deficit'. Mondo Kick Bootay!
--gk!
sparks
  Tesla would also make sure his spark gap was oriented so as to receive some feedback from the magnifying transmitter.
GK noted awhile back that a sparkgap was capable of producing a multispectrum oscillation.  Plasma absorbs em radiation.  Thats how they input power to hot fusion machines.    Thats what harp is doing it is beaming em radiation into an ionized gas to heat it.  (Plasma is collisionless so when they say heat it they mean accelerate the ions and produce scalar waves activity) GK also described the tpu as expanding the action of the spark gap.  So if the sparkgap plasma responds to photon energy of a given frequency and this frequency effects the output of the oscillator and the tpu models the spark gap soon input from the oscillator is no longer needed.  The tpu responds to the photon energy input directly.  Electron circulation through the load could be driven either due to the charge seperation between the ion field and electron cloud found in a plasma or by the circulation of electrons about the ion core which would require a current transformer.  Either way if the tpu is modeled after a plasma the plasma picksup photon energy and converts it into charge seperation and collisionless electronic currents.  Cold currents.
Think Legacy
Spread the Love
giantkiller
Tesla was responsible for the first rendition of this coil.
