innovation_station
great gk
this finally explains ALL that is ...
8)
including fire wind air and water the 4 egales...  egyptians ...  teleportation incase you never guessed im fire ! ;)
CAN WE CALL IT THE MAP OF CREATION?
W814
BTW IT ALSO EXPLAINS DARMA AND SH!FT ... THIS SILLY WORLD THINKS ARE MYSTERIES ...
silly humans!
giantkiller
Yep. Well I want to see specs of the output of the NST I am getting. The iron ring will hold the magnetic current forever. So I am going to build Don's cart tpu. I got the parts, the math, the specifications and the pictures. For his special made capacitors I will use microwave oven capacitors.
One should be able to take a 9kw unit and drive a starter motor to at least move a car off of the resonance powered by the auto battery. Since that is a cold drive force then keep the oil level of the engine at the full level, remove the spark plugs to elleviate the compression, remove the distributor cap and one should be able to move a car off of a 12v battery with no internal combustion. That would be a tremendous starting point for a meager beginning. Or think smaller and apply the same technique to a gas scooter or motor cycle. In other words use the starter motor as an access point. This could then piggyback off the current automotive infrastructure.
Instead of removing the distributor, mount the spark plugs on a metal bracket and leave them connected to the existing system. Route this output in a fashion similar to a Hubbard coil.
So my orignal solutions are to piggyback off the housing and the automotive infrastructure. This innocuous fix would be the grass roots tidal wave that no force could stop. Instead of selling parts here would be the instructions to implement that. Replace the gas appliances with electric and you're done. Consumer prices would plummet. Shipping by truck would have no competition. New laws would spring concerning the number of trailers that could be linked. The train schedules would change drastically because there would be no need to ship coal. The corner gas station would morph to a different consumer base. The business of automechanics would change. If your car didn't start then you simply need a new starter motor until that technology changes. Imagine a neodynium starter motor? Generate big enough fields and you don't need tires.
Another industry that needs to change is the telecommunications. Convert to what Tesla said and all the towers and poles come down. Talk about going green?
The wind and solar efforts would die. Oops...
I said last year that a 9vdc plug in transformer could run a house and got flak for it. So I backed off. The house elec meter would spin ever so slowly.
So I'm back on this. Everybody wants it so why should anybody stop. I can't wait to see the herd switching over. The wild west buffalo runs would pale by comparison.
What you see becomes real.
Also, the reason whales beach themselves is because the Japanese use high wattage, high frequency sound to coral them. They beach themselves to escape the noise. Imagine the torment?
Take Hutchison's devices and mount them to small boats and microwave the whaling boats. Use GPS satellites to corner them!
--giantkiller. Gentlemen... Start your engines!
giantkiller
Think about this:
If you could go back in time with what you know...
It would take a minimal effort on your part to wow the masses. The leaders would be afraid. The rich would hunt you down or exile you. The masses would wonder how you do what you do as simple as your demostrations are. Why 200 years ago you could tie load stones to a water wheel at a grist mill, wrap up copper wire and show electricity. Without showing any output devices the masses would wonder what this mystery is good for.
This is how the world sees Tesla, Keely, Leedskalnin, & Hutchison.
innovation_station
i have had my fill of EARTH THE WAY IT IS....
if they do not stop tormenting ... my creations ...
FIRE FLYS WILL BE SENT!
W814
btw ... i nolonger see farra pissing out side ...  i wonder if they visited him ..... hummmm  i did send a few...
actually the day after i sent them i got conformation they did as they were instructed  ;)
hence the dance they did 4 me ..  :)
