bw
GK, I saw written that Don had 48 different devices.  They all operated on same principal.  Some used stacks of metal plate/insulator caps like the plasma tube thing on page 3-23 read bottom of second to last paragraph it says use as many plates as you want, each set makes an exact duplicate of the full force and effect of the energy present in the magnetic waves without depleting the source.  Another one of his 48 uses stacks of coils, one with sixteen total, one end of the big tank on one device is a badassed capacitor, the other device has boo-coo coils.  Some of the forty eight have both but all resonate and all use a bloch wall to make electrons spin left or right and all catch the electrons on return an convert to usable power.  They get caught at right angles and sent to earth ground, Don says the better your ground the better the performance of your device.
I noticed the wire Don caught in the middle and shows how to get amps, helped me a lot.  A lot of this is old radio.  I remember antennas that draw radio waves in, tiny antennas that preform like huge ones.  I don't know much about old radios but remember tuning c.b. antennas swr just fine tuning to wavelength.  At resonance this should preform like the tiny antenna by drawing energy to it, curving the waves of magnetic energy.  The more times I read Don's book, the more I get.  The man really wanted us to get it, may God rest his soul.
sparks
Imagine bathtub with an inch or two of water in the bottom.  You take your hands and put them into the middle of the tub and open them pushing water towards each wall.  It sloshes up either end then comes back to your now closed hands (palm to palm).  The two returning waves meet on either side of your palm to palm hands.  This wave is twice as tall as the two waves you initiated.  You wait and just as the wave starts to slide down the outside of your "praying" hands you split it and send two more waves out that come back and form a wave a little bit bigger this time.  You do it until the third wave hits the ceiling.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
bw
Sparks you just explained perfectly what I think is going on.  With almost no effort but good timing you can send darn near all the water in the tub over the ends or you could just shake the house a little for kicks and giggles.  I got my brain around that one.
giantkiller
Here are pics of the micro Smith pvc. The L1 slider coil is 1/16 wavelength of the 2 - 200ft L2 coils.
--Giantkiller. Still.
h2ocommuter
geese man, OK all the bad news about Eric Dollard and, God rest his soul is Don Smith dead?
I hope we are successfull soon I would like to shake someones hand who has been inspirational to all of us, God help us to rescue those in need.
Any way I have been contemplating the answers to my questions with the input given. I believe it is time for me to validate my calculations and chronological layout of my replication journal.
I figured out how to find the necessary size of the capacitors in Don's formulas, As W= .5 X CE squared X cps. thus we are using 120 cps because the .5 is used in the formula to designate 60 up and 60 cps down.
Where the voltage is found by the electrostatic voltmeter.
Don stated he was using a small gas engine spark plug and setting the clearance at .0025. This must be my next step because I must be able to get the voltage value reading. to choose my capacitor value.
Two thoughts here; first Nicola Tesla stated that the best performance of a gap is heard as a clap, sharp! Second Don states the faster the oscillations the more energy pumped.
Conclusion; Using a small gap 25 tenthousandths gap you wouldn't have much waisted time thus setting the output by the amount of space involved in between the air gap.
second thought; As Don points out the more negative and less negative pole divisions of ambient non ionic electron; one side of a capacitor the sky, and the more negative surface of the earth, thus choosing the amount of ambient energy desired in the relationship choices.. being less negative amperage air gap and more negative earth grounded spark gap voltage. thus depending on your build nst or plasma would dictate what type is needed for optimal usage.
I am getting anxious to make something happen in the shop.
Time spent studying is as important as work on the bench.
Carefull considerations
Superior planning
overwhelming command of resources.
