e2matrix
This one?  http://www.sendspace.com/file/hips9n
I forget where I got this from but it was in the last week or so and I just put it up here for convenience.  It's about 7.5 Megs.
giantkiller
Tnx but I have that one.
Here is a pic of the best I can remember. Very simple graphics.
Found it. I happy now!
Quote from: e2matrix on July 18, 2010, 01:13:18 PM
sparks
  The pistons below the seesaw do the work or dampen the oscillations.  The pump will keep on pumping taking the low level water and pumping it up into the tanks as long as need be.  The oscillator creates a condition whereby we can become relavent to the scalar electrical potential.  If you allow the tanks to just tap the surface of the water you get waves.  If you use the pistons you can pump closed loop currents through various loads at high velocity.  As the tank that is full sinks it is resisted by the piston and load circuit.  The underground pump with flywheel attached doesnt give a damn about how fast the tanks teeter.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
bolt
Quote from: giantkiller on July 18, 2010, 05:02:54 PM
Within Kapanadze device mag amp is fed by the HT spark which provides both the AC requirements of a mag amp to work and supplies joules to the tank. Only very very low power required. The mag amp IS THE LARGE BLUE COIL is then controlled by a weak push pull sinewave generator to modulate the 25Khz HT spark to 50/60hz sine wave. You dont HAVE to do this 50Hz sine wave its an added feature so that it can run other loads like motors etc other then lamps. But if you do it now as a precursor mixer its 1000 times cheaper then using are real 5Kw inverters later.  This is one little feature the TPU didn't have until SM modified an old triplite inverter to run on 800 VDC.
Tank is excited into high VARS condition. Approx 1/10th of VARS is extractable. To light 100 watt bulb requires 1 KVAR. Ferrite core is there to provide inductance and coupling as it operates in the high KHz region. The over windings on the large coils is for feedback and mag amp operation.
TPU is far  more advanced then kapandze as its a 3 phase version controlled by mag amp toroidal tiny cores where the 5KHZ clock common device on all tpu takes place of a kapagen spark gap which provides AC joules to the tank coils. The 3 phase coils set up their own independence resonance in the hundreds KHz to couple of MHZ pending size of TPU set by the yellow acrylic caps seen on the large TPU's The TPU operates in virtual 3rd phase to create leading edge power factor and revolving magnetic field again in  very high VARS condition. Due to 3 phase and operating in at least 2 or more layers where 3 is best the magnetic field revolves in all X Y and Z planes to provide a spherical field.
The 5khz clock acts as both precursor energy and quencher a super regen to increase the Q and overall gain by at least 1/2 MIO where the mag-amps control the inductance of the main collectors to maintain 3 phase resonance. The mag-amps are a substitution for any power fet or transistor as none are actually required. All this FET coil banging for years total of waste of time and effort!
However they only work on AC so the 5khz clock servers two purpose to enable mag amps to function and to provide quenching.  Mag amps for audio use normally have to run class A Where the mag amp is already half turned on unless push pull class AB but we need them to run in class C magnetic modulation so a magnet is used at 45 degrees to offset the bias. The DC bias is set OFF for class C. This is the most effective operating condition >90%.
You can bet SM had both nice magnetic audio amp and tube amps to play with:)
Because its class C the hardest part is getting the TPU to start so a magnet is required to sweep over the collectors to get the first pulse going then the mag-amp turns on and continues from there. SM always  carried several magnets around in his pocket one to set the bias and the other often cupped in his hands in case one of the TPU needs a kick start.
Again the collector tanks run in high VARS to provide powerful magnetic field so a 1000 watt device will have least 10-20 KVARS in circulation.
Well as this thread is called the final design i just added my input again.
So if you REALLY want a TPU before the lights go out soon for whatever reason like solar storm, grid overload or even your heart says now is the time to do something we wasted enough time already. Whatever then donations are always welcome!
PS no deep bunker labs and NDA's please i had plenty of those offers already.
stprue
