Scalar Wave - Energy
Started by mondainmax, November 02, 2009, 04:19:24 PM
sparks
      Checkout plasma waves.    They happen at all sorts of freqs. They will setup standing waves at around 5kz due to the electrostatic field between Earth and the magnetosphere and the properites of air.   Tesla would make these plasma things he called brushes in a tube with different gases in them.  When he flexed his arm muscle the brush would dance. It seems that plasma responds to all sorts of electromagnetic waves.  I imagine a plasma exposed to infrared would setup infrared wave length oscillations.  Imagine that.  An ionized gas in a tube converting randomized heating into well defined electrical oscillations.  As the oscillations intensified from the infrared input would the field appear cold or would it appear hot.  I found that the field gets cold because the infrared is no longer being reflected by neutral atoms because there aiint any around they are all ionized an part of the conversion process.  The conversion process is simple.  Space plasma cools off and forms hot gases.  Hot gases cool and become liquids.  Liquids cool and become solids.  Solids cool and become bose condensates.  Bose condensates cool and become black holes.  Blackholes explode and become plasma.  "intelligent" life has no preference as to what form of matter it uses in its organization.   In other words when something chills it gets organized.  Just energy with a different phace.
http://www.hmo.ac.za/old_site/Space_Physics/tut/tut.html
t
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
xee2
@ Loner
Inductive coupling only works at close range - that is it falls off very quickly. I do not remember the equation but I will do some digging. In my test, if the receiver loop was more than an inch away from the container the LED would not light. Magnetic field shielding is much harder to do than electric field shielding. The best materials are high permeability ferrites. Check this site:
http://www.lessemf.com/mag-shld.html
But I think a 1" thick steel plate would be very effective (and very heavy). Shielding against RF signals is like shielding against electric fields. A 100 watt RF transmitter would not be able to transmit out of the container I was using. So your FM transmitter was not a good test. BUT, even high voltage power lines only produce a very weak magnetic field signal 100 yards away. So anything you were doing that could get through a steel enclosure and be strong enough to be receive 100 yards away seems very exceptional.
xee2
@ Loner
Tuning to me would imply an RF signal. Inductive coupling is only dependent on current and distance. It can be repeated at some frequency, but that is just how often the switch is closed to allow the current to flow. There is no improvement at certain frequencies.
I sent you a PM.
You might find this video helpful:  http://www.youtube.com/watch?v=t23iXhEiQUc&NR=1
NOTE: his mike signal works because the radio waves from it are short enough to get through the holes in the cage he is in. If the cage was solid they would not go through.
sparks
   Ionization is an endothermic process.   It requires heat.  When this endothermic process occurs in open air it collects heat energy from the air.  Randomized kinetic energy is converted into electrical energy.  It's like this.  You have an electron filled valence shell neutral atom.  The entire atom is moving.  When you ionize the atom the electron that is bumped out of the valence shell  by the ionization photon has the kinetic energy of the parent atom on board.  This is not frindge science this is just thermal energy conversion to electrical energy.  You show me a neutral atom that isnt moving round here.  Changing the randomized movement of neutral atoms  into non randomized movement of it's associated parts.  Molecules are even easier to bust.  At any given time the molecules atoms become ionized while the mate atom becomes neutral.  There is an electrical oscillation of the constituent atoms of a molecule between being neutral and ionized.  Stanley Myer was always talking about the resonant frequency of water as well as Keely.  This is what these guys were talking about.   Molecules are said to share electrons.  They are Indian givers.  Give me that electron back no fuck you its mine,  No its mine ok have it for a nano second see if I care,  I got your electron ha ha.  No you dont I just grabbed that bitch up while your were talking.  Then why is it over here whith me asshole.  Becaise I gave it to you and now I want it back  etc. etc. etc.   Meanwhile an electrical current is oscillating at a very high frequency due to electron sharing in molecular bonds.
Think Legacy
Spread the Love
xee2
Loner,
I was wrong about inductive coupling falling off very quickly. I have been doing some checking and it actually falls off at the same rate as radio waves.
