Scalar Wave - Energy
Started by mondainmax, November 02, 2009, 04:19:24 PM
sparks
   What I see is Tesla was producing a lot higher frequency radiation then kilohertz. The extra coils on top of the electric motor changes the time interval between when the voltage appears across each winding in the motor.  This is like getting doutble voltage effects but at different times.  The voltage will still be 120volts to each winding but it will be out of phase.  Changing the motor into a twophase motor from a singel phase scource.  Two circuits powered up for the price of one.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
xee2
@ Loner
I did a quick test using a pulsed 15 KV source (ignition coil I have measured the voltage on). I put two leads on the output and then put a neon bulb on the end of one lead. With a distance of about one foot between the neon and the other lead the bulb was blinking. Capacitance falls off as 1/distance. So I would expect that if I had an output three times higher (45 KV) that the bulb would blink with a 3 foot spacing. I did not test with a tube since they do not work well with pulses and need more voltage than a neon. The unattached lead on the neon was a bit longer than 1 inch.
xee2
@ Loner
I did a test by accident. I had a fluorescent tube sitting on the table while I was doing something else and noticed that it was blinking. It turns out that when each end of tube was placed within about 2 inches of the HV output wires from the coil it would blink as the coil was pulsed (nothing connected to either end of tube). So 15 KV seems to be enough to light a tube wirelessly if it is within about 2 inches of the output wires.
pese
This effect is since jear good know.
Ist ist only an effect from RF distortion that is produced from the spar pulse  (and will als produces from square wafes with short on an fall times.
If you will test this out.
open an AM transistor radio in the room,
and think about ths.
Gustav Pese
forest
Does effect persist when you put this bulb into pure water (distilled) ?
