Scalar Wave - Energy
Started by mondainmax, November 02, 2009, 04:19:24 PM
0 Members and 16 Guests are viewing this topic.
pese
Quote from: BEP on February 06, 2010, 10:13:23 AM
@Pese
Even laboratory pure water will become hot in a microwave oven. The heat is primarily from molecular excitation, not electrical conduction.
I think you will need a one-wire connection to light a submerged lamp. The surrounding water simply acts as the dielectric of a capacitor. This allows for capacitive coupling back to the transmitter. This capacitive coupling is always there and the reason most one-wire and other magical experiments work.
The resistance of most drinking water is high enough to only change the impedance of the antenna, wire or lamp submerged within it. It is not a dead short.
Jes i belive that, but i never try it.
I was thinking over the posting, because ohmic resistance  is high.
Like an INSULATOR
and water that contains
salt or minerals
make it conductive.
so possibly   the time to heat it up in micro
can be different.
I an sure that some members will test this out
Pese
xee2
@ Loner
Quote from: Loner on February 07, 2010, 05:37:08 PM
Any Errors noted at this beginning stage?  Any comments?  Please feel free as I have no idea of what I'm doing, beyond jumping into the abyss, sticking my hand out and hoping there is a rope there, somewhere......
I am not sure I understand how your coil is made. This is a bad drawing but I hope you get the idea. Is this what you are doing?
xee2
Hi Loner
Before I can even think about how it works I need to understand how it goes together. Is this a bit closer to your construction?
xee2
@ Loner
Quote from: Loner on February 07, 2010, 10:16:56 PM
Maybe a schematic is easier.  This is quick and dirty, and not zipped.
Hope this makes sense.....
Thanks. Does the other coil then go over all of this?
sparks
      If an ElF wave (dont make alot of these this bandwith is very controlled)  produces a current aka wind between the quarter wave nodes and antinodes then this current passes through every conductor in the path between transmitter and first quarter wavelength node.  This wind when meeting obstacles of a different density than the media in which the wave is propogated will induce gravity waves in the denser media.  You can also look at various geometric shapes that will concentrate currents into particular parts of a conductor.  A conductor lieing perpendicular to the transmitting tower will try to concentrate the current in the skin of the conductor.  The depth of the current determined by the crossection radius velocity of current and angle of incidence.  Im tired confused and need to sleep on this one but spent alot of time out working in the wind today near the ocean.  The ocean waves just looked to me like slowed down wind.  Gotta nap.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
