another way to fight lorentz
Started by mr_bojangles, November 07, 2009, 12:59:59 PM
should i move this into a different section and if so what should it be considered?
gravity powered device
1 (14.3%)
magnet motor
3 (42.9%)
something else
0 (0%)
leave it here
3 (42.9%)
Total Members Voted: 7
mr_bojangles
Quote from: broli on November 07, 2009, 02:28:06 PM
That's quite an interesting take. Are you using the concept of the homopolar generator to generate electricity?
i thought about that and considered two options
the first being a homopolar style like you asked, the other is simply replacing the cyllinder magnet with a non magnetic materal, drill an odd number of holes all the way through and secure strong magnets with alternating poles, allowing both sides of the magnet to induce electricity with the same stator set up
i feel as if if the right momentum were found in combintion with magnet/stator set ups, it could at least run iself, consdering it needs only to overcome the friction of the axle, as well as the balanced lever type system
i like this design because it will stay semetrical no matter how many generator type mechanisms we employ, and each one significantly increase output
anyone/anyting else?
i dont have materials for so its up for grabs if somone wans to be the first to build it
"If at first you don't succeed, try, try again. Then quit. There's no point in being a damn fool about it."
-WC Fields
mr_bojangles
Quote from: lumen on November 07, 2009, 02:50:59 PM
You could also use a 3 gear system to keep the stators from rotating.
One gear on the center hub, one intermediate gear and one outer gear on the stator.
As it rotates, the outer stator remains still at any speed.
Of course, you need two additional gears on the other side also. (intermediate and stator)
that could work, but i want to minimize moving parts,  every gear is more friction, and i want that to be a low as possible
with my original one, the axle is basically the only concern we have as far as friction. the stators will be on an axle, but we do not directly influence that with our motor. gravity is fighting this friction to keep it upright. this means every time and all the time we only need to give enough energy to rotate the mass of the system, which will always be balanced
i will add a drawing in a bit, showing how to possibly make it most efficient
-WC Fields
mr_bojangles
im adding a poll because i have no idea what this would be classified as, and i feel its more than half baked
if you don't want to vote just leave a post as to where you believe it should be relocated, if at all
-WC Fields
lumen
I think the problem is that in the end, the entire system is the same as one that rotates the magnet only or if you think of the frame as a conductor, then it is a stationary disk with a rotating brush.
In any case the first one doesn't work and the second one could be built much easier but is still COP<1.
mr_bojangles
it is absolutely different than spinning a magnet, or brush system
the entire problem with directly spinning the magnet obviously is lenz law, because the motor or spinning mechanism is attached to the magnet, meaning it takes 100% of the backwards force due to induction (lenz)
so it would be easy to make an OU device if this phenomenon didn't occur, basically its all lenz fault
the whole point of this is to not do this, not directly influence the magnet, creating lenz less rotation
my whole theory behind this is to make that force be absorbed by a different medium, other than our motor
everyone makes the mistake of attaching magnets to the axle of their motor in the wrong way, because the lorentz force is going against the turn of the motor, which means more and more energy
in my system, lenz law will not effect the motor, making it completely different than any other generator
even if the lorentz force isn't completely expelled into the stator, it will have absolutely no effect on the motor turning the system
the only reason this has any validation is due to the fact that this generator has a constant input of energy and while magnets exponentially increase output energy with speed, my system will actually require exponentially less with speed due to the flywheel effect
normally this would be compensated by lenz law...but not here
-WC Fields
