another way to fight lorentz
Started by mr_bojangles, November 07, 2009, 12:59:59 PM
should i move this into a different section and if so what should it be considered?
gravity powered device
1 (14.3%)
magnet motor
3 (42.9%)
something else
0 (0%)
leave it here
3 (42.9%)
Total Members Voted: 7
24hosting
I have some magnets that came out of some old hard drives.Is there a way to know what kind or how strong they are. I mean there feel very strong?.
gravityblock
Quote from: 24hosting on December 08, 2009, 05:32:09 AM
They're probably strong neo magnets.
If there was two magnets attached to a piece of metal, then they're more than likely axially magnetized magnets (north pole on the heads side and south pole on the tails side, or vice versa).  If there was a single magnet attached to the piece of metal, then it is more likely a radial magnet ( north and south pole on both the heads and tails side).
You can always use either pole of another magnet to see how your hard drive magnets are magnetized.
mr_bojangles
use a magnetic rod and place it on the magnet, magnets are not magnetic in between poles so if it doesn't stick you have your "equator"
@GB, what did you think of the rod idea
"If at first you don't succeed, try, try again. Then quit. There's no point in being a damn fool about it."
-WC Fields
24hosting
Great . But I don't have one lol. But I appreciate the learning's.Thanks
gravityblock
Quote from: mr_bojangles on December 08, 2009, 02:10:47 PM
My mind says it works and my little model says it may work.
If it doesn't work, then a few small additional modifications may be all is needed.  My best guess is no modifications is needed, but you never really know until it is tried.
It appears to be a very promising idea.
