Flynn's Parallel Path
Started by longwolf, March 10, 2006, 04:07:45 PM
jake
The invention proceeds from the realization that between
electro-technology and the fluid engineering an analogy exists
existing existing-be-being these in it that an electromagnetic field
around leaders bent one as desired and a zone of flow are described
around arbitrary-any vortex filament by the same connection, i.e. Biot
Biot-Savart Gesetz.Die sizes of "increase in magnetic field strength"
und"Geschwindigkeitszunahme" of the zone of flow corresponds therefore
each other.....
jake
Probably why motor designers hate open ended magnetic circuits.
Looks like the arrangement of the materials is very important.
jake
User..1  You are right on all points.  Build it and let me know how it works.
de Lanca (is this the proper way to address you?)
I have found the patent, and I printed the drawing. (attached to this post)
Help with this: (Wie die meisten faulen Amerikaner spreche ich nicht Deutsches)-blablafish
1 = housing/case?
2 = shaft?
3 = switch cam?
4 = input power connection?
5 = electromagnet?
6 = dauermagnete - permanent magnet?
7 = ? magnetic bearing?? some kind of bearing.
8 = ? plate??
9 = Isolator?  Magnetic isolation or physical (shock) isolation?
What is the theory of the motor? It is not clear why this is more than a simple motor.
I don't want money for the drawings.  I want to find the right project and help.  I can't spend a lot of money, but I have a lot of tools and resources that can be helpful if we can decide on a project to design and build.
I would like to look at some promising magnetic motors and design our own, using the best ideas.  Then we can work together on the design.  We can share drawings and information here until we think we have a good design, then build it and test.
I will study US5463914 tomorrow.
gyulasun
Hi Jake and Lanca,
I found the English Abstract of this patent at the European Patent Office.
Also I included my understanding/best guess on the Figure's numbered text. I used online translator and a German technical dictionary for the Figure text.
DE3602039 Machine for obtaining energy, without any hazardous materials, in accordance with the energy principle of nature
Publication date: 1986-06-19
Inventor: GRAMBERG HANS-GEORG-WALTER (DE)
Abstract of DE3602039:  In the case of the subject matter of the patent application, the electrical input energy which is supplied in a pulsed manner is absorbed simultaneously by both poles of the electromagnet which is mounted, as is shown on the attached schematic drawing, firmly on the outer framework of the subject matter of the application, and is at the same time forced as fast as a flash of lightning from these two poles to both poles of the permanent magnet which in each case rotates past and is in the form of a horseshoe, from which permanent magnets the same input energy is at the same time once again forced back on to both poles of the electromagnet as fast as a flash of lightning and thus acts in a repelling manner four times, that is to say twice with double the force, as fast as a flash of lightning. All the repulsions are in the form of two beams and are mutual, that is to say in each case two times twice, that is to say four times, from in each case one input energy quantum, as in the case of the energy principle of nature between the sun and earth. In the case of the subject matter of the invention, when the electromagnet which is mounted firmly on the outer framework is subjected to current in a pulsed manner in each case, this results in the rotor rotating four times as quickly, on the one hand as a result of the quadruple full-inten-sity repulsion from in each case one electrical input energy quantum, without any moving-away or passage loss in terms of input energy and on the other hand as a result of the traction of the permanent magnet, which is located on the outer edge of the rotor, to the electromagnet shortly before it is subjected to current, in each case in a pulsed manner, as fast as a flash of lightning.
Figure explanations:
1 frame of the machine
2 rotary axis from brass
3 arm-switch fixed to the rotary axis
4 current source
5 electromagnets
6 permanent magnets in horseshoe form  (dauer magnet=permanent magnet)
8 (End)Supports
9 insulating pieces  (not clear for me if they are shock absorbers or magnetic shieldings)
7 full-ring-shaped horseshoe (i.e. toroidal) magnets facing (each other) with their side Poles of the same name to compensate the earth attraction (gravity),  with change of the current supply contacts (as) the rotor walks around on the left or on the right.  (I put my extra, explaining words in parentheses, they are not included in the original German text)
Unfortunately it is also not clear for me yet why or how this setup is overunity.
Gyula
jake
Thanks, Gyula
The design is not mechanically strong either.  If the method of operation turns out to be acceptable, we will have to change the mechanical design, becuase it will break apart from centrifugal force, "as fast as a flash of lightning"!!
I studied http://www.kundelmotor.com/ last night.  This is interesting - appeared here in another topic.  It doesn't look like an overunity opportunity, but it has some design features that I like.  I wonder about the eddy currents in this type of action.  It looks like the concept would minimize eddy current effects.  The concept is good but his implementation is not.  I think many improvements can be made to his concept to create something interesting.
