Hilden-Brand Magnet Motor
Started by JackH, March 10, 2006, 11:58:55 PM
JackH
Charlie_V
Hehe, seems like you got everything covered.  Those capacitors you have across the coils, if you get time, move them so they are in series with the coils.  Then, play with the values a little till you get the most power through.
Having the capacitors in series will make the current in your coils much larger, and the voltage across them lower.  So you'll get a larger driving magnetic field.  Having the capacitors in parallel (shunted - across the coils like you said) makes the current in the coils lower, and the voltage across them higher.  Its whatever works best for you I guess.  Just some tweaks I thought might be advantageous at some point.
Good night, I'm off to bed!
yorkshireminer
Jack everything has a resonant frequency. Tuning forks are perhaps the best example different forks resonate at a different frequency. Tuning in a radio, you are doing nothing more than making your radio resonate at the frequency of the station you want to hear. You seem to have instinctively worked it out your self. Just a thought when you fire you valve do you switch it off as soon as the magnet in the rotor has passed the stator valve or do you let the rotor travel a fair distance pass the valve. It would seem to me that the back EMF generated in the coil would act to retard the motion of the rotor if you switched off the valve directly after the rotor magnet had passed the stator magnet. Magnetism as far as I know still works by the inverse square rule. Secondly could you not use the back EMF to help fire the other coils and there by saving energy. Thirdly could you not get one of you fans here to help you with the electronic  circuit. The secret of your valve ie, its efficiency is in its construction, not in the voltage and the amperes that you put into the circuit, could you not write down what is needed the voltage and amperes needed for the different coils and the timing and let one of you more technical fans here on this thread design it for you. I am certain many would do it with pleasure after they had signed a non disclosure agreement. I am deeply sorry that the greedy bastards tried to screw you, it seems to be about par for the course in this world. What does worry me, and you don't mention it is how is the patent application coming  along? They seem to be dragging it out, and if it is suppressed by the government, which they easily can do, then all you work is for nothing, you will effectively be gagged , you will not be able to disseminate your work and the comfortable old age you have been looking forward too will be nothing more than a dream. By the way jack post a little bit more frequently you get a feeding frenzy going among your fans and that is good for all of us.
Deep Regards
Yorkshire miner
JackH
Charlie_V
Oh, the diode in the line with the cap.  I was thinking you had like just a coil and a capacitor.  Yea diodes would make that resonance thing I was talking about more complicated.  Nevermind it then.
