Hilden-Brand Magnet Motor
Started by JackH, March 10, 2006, 11:58:55 PM
0 Members and 25 Guests are viewing this topic.
dingbat
QuoteI have only one thing to say currently.   Everybody is bitching about high gas , high energy, high heating, high everything, however no body is will to put a few bucks out to help the situation.
If I can come and take measurements on your motor(s), and my measurements validate your claims, I will help you complete your projects.
JackH
Ergo
Quote from: JackH on March 10, 2006, 11:58:55 PM
However since these pictures were posted I have made several major break throughs.
I have found out that  the valve that I invented werks much better at a low rpm.
I have built a motor that was especially built to operate at around 600 rpms.
This new motor has been tested on a prony brake and the voltage/current was
monitored. Input was 2.2 watts and the output was over 56 watts.
At a pull down of around 200 rpm this motor exhibited over 500% efficiency. :o
I think that means it to be over 400% over unity.
More  will be posted about this motor in the future.
Quote from: JackH on June 18, 2006, 09:46:56 PM
I have built a two inch rare earth magnet model (two valve, two rotor) of my
invention that has proven to produce over %500 efficiency.
Quote from: JackH on September 05, 2006, 09:44:13 PM
I had an electrical engineer from Goodyear Atomic come up to run some tests on the
last motor I built, this motor was only at two thirds built.  In other words it only had
two rotors/valves, a complete motor will have three rotors/valves.
His tests showed it running at around 300% efficiency or better.
Quote from: JackH on February 15, 2007, 08:37:46 PM
The two inch motor I had tested was just a two valve motor, it had some coast time.
However it still tested out to be two times overunity, with a third valve, I'm sure it
would have done much better.
Quote from: JackH on February 22, 2007, 08:27:30 PM
I have a motor that has proven to produce twice out than in.
Quote from: JackH on February 27, 2007, 09:42:40 PM
Some of the motor that I have kept are not really over unity because they are
running at high RPM levels.
The five valve radial motor was tested at about 100% efficiency, however it has
very little power because it runs at high RPM.By the way if I had a motor that was
five times overunity, would you think I would  need your help then. I don't think so.
What is going on with you Jack? Are you trying to shit us?
All of your reports on your earlier motors stated overunity
from 120% to 400%. This was also the high RPM versions.
And now you are saying that you don't have any overunity motors?
Why do you keep being inconsistent in your story?
If you have any low RPM motor capable of overunity, then let
dingbat for gods sake test it and let him help you out.
He's willing to help you complete your projects if your statements are correct.
This means money, and that's exactly what you want from people.
Well Jack, I'd like to ask you one thing only.
Have you ever had any motor capable of overunity?
dingbat
Jack,
Thanks for the response.
Dingbat
idnick
Hi Jack
Quote from: JackH on Today at 02:42:40 AM
"Some of the motor that I have kept are not really over unity" because they are
Why in hell would you keep the under unity motors but not the OU motors ?? ??? Scrap em !!!
What did you do with the over unity motors?? ???
Like this one:"I had an electrical engineer from Goodyear Atomic come up to run some tests on the
His tests showed it running at around 300% efficiency or better. :o
I think I'm gonna have another Hamm's and think this over and if I can't figure this out before I finish the first Hamm's, I'm gonna have another and another till I do. ;)
Dave
Hamm's the beer refreshing !!!
