Hilden-Brand Magnet Motor
Started by JackH, March 10, 2006, 11:58:55 PM
Hello JackH,
the investment answer from our side will be negative,
not because of the technology,
but cause the price/effect ratio !
A 3KW-Hilden-Brand-Motor,more the generator, will never produce an acceptable
e-KWH- price which could be a solution for the global energy kind change !
"Acceptable"= under 1 Euro-Cent per KWH
This is my critical point,from commercial view, not about your honorable temptation
to find a way for solution of the "fossil energy crisis " !
Sincerely
            Christoph de Lan?a
p.s.: "Overunity" as periodically phenomen is physical standart:
       "Physics"-Alfred Nobel-Award 1989
Paul-R
Quote from: JackH on March 09, 2007, 10:23:42 PM
Hello Paul-R,
Well I would really like to get ahold of this Richard Branson.  He may be the answer to all of us.  And also about the grants, where do you find out about them.
I am from the USA,  Ohio.
Later,,,,,,,JackH
What is your nearest university? Sometimes grant givers like co-operative ventures.
Would you be up for this? Could you propose a generator as well as a motor? Could
you produce a better generator for a wind turbine than what they are using now?
Could you design two projects together so that funding for one project helped
the other?
Here is the article that I talked about:
http://environment.guardian.co.uk/climatechange/story/0,,2009530,00.html#article_continue
You could draw up a shopping list of what you need.
He might be able to find alternative funding, or a pilot study, or get your bills paid, or get Virgin Altantic's workshops to get a job on a lathe for you. Sometimes, a letter
sent by old fashopined steam post gets more attention:
Sir Richard Branson,
Virgin Ltd,
120 Campden Hill Road
LONDON. W8 7AR.
British Isles.
All the best.
Paul-R. (Grant info coming shortly).
JackH
Hello Paul-R,
Thanks for all your info.  It just may be what I'm looking for.
Thanks again,,,,,,JackH]
Low-Q
Hello Vidar,
Yes I did disasemble the first one, I needed to use some of the parts to build the big one.     As for now I am sure I can get it running again with out the use of magnets. Yes the wheel takes many parts. I have been working in the shop now for about a week just building small parts.   One thing you all need to remember is if it were easy to build it would have been built by now.   And the same falls true with the magnet motor.   It takes lotts of money just to keep up with the cost of building parts.
Later,,,,,,,JackH
OK. Please remember to take several pictures and a videos of this motor next time it works ;) It will help you to remember the mechanical setup if you take pictures of the composition.
I can't understand you're building workable machines and destroys them without taking care of the mechanical setups... :-\
Br.
Vidar
JackH
