Second Stage Joule Thief Circuits
Started by Pirate88179, November 21, 2009, 02:06:51 PM
gadgetmall
@paul . their are no claims for the above other than the bcap is over the unity of the run battery . if you care you calculate the total loss on this old battery please . its like 2 tenths and something ?This is not the  the first Experiment i did that used a nimh battery that had 5/1000th of a drop and charged the bcap to 2.6 .. you didn't have to go back but to page 996 on JT thread  ??? discovery started there . and also this nicad experiment was just for the fun of it to see if an old battery that was unshorted several time with a blast from 12v would do anything with this projects .Answer :yea. and so to make this simple circuit self run its a matter of a simple push button to connect the Bcat + to the nicad + and monitor the AA battery until its back or higher than it started and the process can start over . done this on another one .you dont need the Ou circuit controller board to see this there is plenty of power left in  the bcap after you do this . even if its not up to its rated amperage  i can easily blow a 20amp fuse trying to measure it with my fluke charged to even 1 volt .i cannot do that with the aa battey.
so dont try that a home folks unless you got lots of fuses !
PaulLowrance
Hi gadget,
Today I'll try to build a JT in the lab and see how well it charges various rechargeable batteries, but my bcap has not arrived yet. No idea when.
Anyhow, here's your quote I was referring to,
Quote from Gadget, "I have demonstrated over the unity of a primary source in the Jule thief thread . from an aa battery 2500mah i have charged an ultracapacitor to full capacity with only a few microvolts of loss from the battery 1.4 volt battery ."
I was unable to find any of your data logging that shows the AA battery dropping a few microvolts.
Paul
gadgetmall
Quote from: PaulLowrance on November 25, 2009, 10:48:46 AM
Hi gadget,
Paul
ok i did not log it on paper as it was Experiment 1 and if you read all my post starting  on 996 to somewhere aroung 1003 you can write the numer down if you wish . I sopped posting and started building whnt the last number were over 2.400 ove the bcap . results after i stopped the test hours later and let it fill the cap were 1.490 from the start of the nimh battery test which was 1.495 in the beginning and the bcap start was .521 and i ended it a 2.601 . this is what i asked for replicators  but i didn't get any until recently proving this . I won't post anymore results as a group of us are doing our think in private now and i leave it up to everyone to make there  own and prove to themselves . i sadi all i am going to say . I may show My completed Stephan unit but thast it . Also the unit will certainty will show a selfrunning light at the very least  . whether it pulls it from the bcap or not its the first OU toy every made that is public and usefull. Build one and you will at the very least had a self runner . the final circuit may or may not be publicly displayed . COnstant revision are being do oon the Pro Ou controller . you guys have all you need to make it even if you don't use a controller .
Al
Gadget, attached is a simple line chart for the data you just post. I'm just confused whether the run source is a battery or bcap. If you inform me on that I can change the title of the chart.
PaulLowrance
Albert, a Gadgetmall only thread would be nice. Would you like to start the thread?
