selfmade homemade DIY supercap ultracap bcap boostcap
Started by hartiberlin, November 25, 2009, 11:51:54 PM
Paul-R
What capacity and voltage rating are you guys expecting?
QuoteWhat capacity and voltage rating are you guys expecting?
Great question!  I have a feeling it is going to be in microfarad territory, not supercap territory.
Experiment and learn as they say.  You will probably need scopes to measure your capacitance's.
MH
hartiberlin
It depends only on the surface contact area between the alufoil and graphite.
If you are using 1 x 1 meter of alufoil and 1 x 1 meter of graphite paper,
you should expect a capacity in the range of 100 Farad or more.
Have a look at this good PDF file:
http://www.ansoft.com/firstpass/pdf/CarbonCarbon_Ultracapacitor_Equivalent_Circuit_Model.pdf
Regards, Stefan.
Robert
AA batteries have carbon cores that can be reused....
Old batteries is an endless supply of carbon powder.
V_Schaub
Hi.
I have few questions regarding the main design in this topic.
In my test project i want to create 400V capacitor bank to charge one 2kw device for one hour.
1.) How much supercapacitors should I build to make this work and how much Farrads should one SC need to have ?
2.) If i use aluminum/salt/graphite (active carbon or maybe graphene ) design, would it be possible to create 400V / 200F capacitor ? The size does not matter, it can be big cca 1 meter and over 50cm thick
3.) When you put saltwater between graphite and aluminum you have created battery. My question would be:
What will happend when aluminum will be coated with aluminum oxide. Basically when aluminum starts to oxidize ? Will the supercapacitor still work / will it loose its capacity or something else ?
4.) What would happend if i would use carbon or graphite as second plate ( instead of aluminum ) ?
Thank you in advance for your ideas/comments !
