The Heavens are "shaken"....the Sea is Agitated.....
Started by TechStuf, November 29, 2009, 02:37:59 PM
nitinnun
a tree is 2/3 positive,
and 1/3 negative.
the tree's wood is the positive connection.
the space around the tree is the negative dis-connection.
most of the starseeds were more than 2/3 positive,
and less than 1/3 negative.
which means they could only shape a rounded, blunt tree.
that had too short/simple of branches.
they could not shape the optimal 2/3 and 1/3 tree,
that creates the largest amount of polarization.
that gives the largest amount of energy, to the tree.
so the starseeds incarnated onto this planet.
because this planet was the best possible place,
in which to learn the constructive parts of negativity.
so the starseeds could beef cake up their negativity,
and make that 1/3 shine.
so that once they go back to 5D and 6D,
they will be able to go higher than just 5D and 6D.
yet still have any idea what they are doing.
and that is the story of why we incarnated onto this insidiously screwed up planet.
because despite its appearance, it had something that we needed.
we had to get the golden key out of the huge monsterous toad stomach.
and the huge monsterous toad didn't want to go down easily.
of all the millions of starseeds,
i have one of the firmest grasps on the golden key.
mainly because i suffered extremely,
in just the right ways,
to find the key.
i've been so emotionally mummified,
that i might not be able to go to 4D or above this time around.
my fight or flight mechanism is fused into the on position.
but that doesn't matter.
because getting this freaking key,
was a far harder task,
than going back to 5D will be.
Cloxxki
Quote from: sparks on December 12, 2009, 07:33:07 AM
  Jesus was sent to us as a teacher as many have been sent before.
[/quote
Did you take note of the one sent to us after Jesus? If Jesus is real from the vague recollections in the year zero, one that came almost 20 centuries later sure should be hard overlooked, sough after so vigorously by billions of god fearing superbeings.
How did this become religic anyway?
And, if this is the end of time, can we conclude mankind is actually a failed creation? That would suck as an invention. Yes, we were created, and we were the creator's worst work, despite all the help we got.
nitinnun
mankind is not a failure.
mankind is a training ground.
souls incarnate onto this planet,
get the living stuffing beaten out of their well being in some way or another,
learn something useful (if they are lucky and smart),
then incarnate onto some other planet.
another planet, where the suck-factor is much lower.
yet the opportunity for spiritual growth, is also much lower.
earth is a free will planet.
a planet where there are no imposed rules.
the rules of our legal system,
are just some furry monkeys thinking they have a right to boss others around.
they are not REAL rules, that were decided and agreed upon by a majority of the population.
then enforced by either magnetic technology, or the spiritual heirarchy.
for example, on many other planets, it has been implemented so you cannot swear.
if you try to swear, there is magnetic resistance against you doing so.
if you try to swear lightly, you just mumble and stutter instead.
if you overcome the magnetic resistance with raw force,
you might barely be able to tell someone off.
in a horse whisper.
squeezing out 1 or 2 words.
if you really, really put your intent into the effort.
it works the same way for theft and murder.
but the definition of an action,
and the form of the resistance,
depend on the settings.
on some planets,
you merely hit a solid magnetic wall,
if you try to do something that is against a rule.
on other planets, they are less nice.
and the force of what you do, is turned back on you.
so if you tried to cave in someones skull with a hammer,
your "intent" and "effort" would be reversed
and your skull would get caved in instead.
under the very force that you created,
with the muscles in your arms.
every action in the universe, has a magnetic signature.
so any action can have magnetic resistance,
set against the action.
if you have the magnetic science that can do it.
it is very similar to magnetic manifesting of your will.
only it is in reverse.
but i have yet to make a post, explaining that subject.
