Ultracaps tested for excess energy
Started by PaulLowrance, November 30, 2009, 12:47:01 PM
PaulLowrance
Did gadget go to the mall?  ;D   Just kidding. Oh well, I'll wait awhile longer for him to give the thumbs up for my JT before I'll just go ahead and connect it to my bcap0650.
Paul
gadgetmall
Quote from: PaulLowrance on December 10, 2009, 11:42:52 AM
Wow, that's incredible. Are you saying that your 2500mAh NiMH battery has recharged the bcap0650 from 0 to nearly 2.7 volts seven times without regarging the 2500mAh battery??
Paul
No i didn't mean down to 0 volts . none of My bcap have ever seen 0 volts . even from the factory all of them carried at leat .100 volts . Where they are dead here and wont run silicon transistors is .5 volts . this is where they start when they are being charged . I have not discharged one on this design down past .8 volts so i guess that invaladate My post above :) However if you had two bcap you can see then charging each other and swaping each time teh charged bcap reaches about .4 volts over the run bcap . got one swapping now for the 6th time . Just Bcaps. I am confident the battery version i posted will hold its own well past the three month prize limits .
gadgetmall
Quote from: PaulLowrance on December 10, 2009, 10:49:44 AM
Albert,
When I adjust the JT to 19mA input, the DC current through the 1N34A diode is 7.2mA. At 10.25mA in, the 1N34A current is 4.9mA. Does that sound correct?
Paul
Sounds good actually a bit higher than mine . at 21 volts out from the diode i get 5.5ma  so your good to go .
I agree .: STEPHAN   . I second the motion to promote Grounloop to Ellite Member Status for his Over abundunt talent and gifts to the fourm community In free energy Research ! If anyone deserves it he does!
Albert
PaulLowrance
I better start the test now because at 19mA it will take 23 hours to charge the bcap0650 from 0 to 2.6 volts. To do that 4 times is 4 solid days.
19mA is about the maximum you recommend for this JT in terms of efficiency?
Paul
gadgetmall
Quote from: PaulLowrance on December 10, 2009, 12:23:04 PM
Paul
I do as the people in the Jt thread were the first to product a circuit lower than 20ma which was the first published Jt from Big Clives and Evilmad scientist . So anything below that is Super Jts. Mine are adjusted to 13 ma which is low but enuff to do the job . At that point i didntcare about charge time and was looking more for battery life not sinking so fast it couldnt be regenerated  so to me 10 -15 ma is a good place . I am not seeing any real current change from 5 ma regardless if i adjust to 13 ma or 21 ma .  a .5 difference . Its propably the china 2n2222a transistor . Some other brand will be different like fairchild .  i also change the diodes to 1n60 . I had a bunch of old germaniums . They can still be bought and are still manufactured .
