Ultracaps tested for excess energy
Started by PaulLowrance, November 30, 2009, 12:47:01 PM
PaulLowrance
Actually for now all I'm testing is an ultracapacitor, not someones circuit. Gadgets & other people have said these caps are OU.
Paul
Kator01
Hi,
some member in this thread :http://www.overunity.com/index.php?topic=7987.480
posted a document on low-loss-charging of capacitors.
In the file attached one should read first the reference-document of Heinrich which was the first report on this phaenomenon.8 See first reference at the end of this file
Kator01
powercat
Paul,from the testing so far
you are saying that you get better results when the capacitor is warm  :o
how many times have we seen circuits that gives off heat, which normally has no use at all
I wonder how much heat the capacitor can take before it loses its maximum benefit
cat
gadgetmall
Quote from: PaulLowrance on November 30, 2009, 03:07:42 PM
Paul
You are Not alone . Go ahead and Say what your numbers represent . I will take the Rap. It was just a matter of time until someone actually used these bcaps for other than tank cranking and regenerative braking . So what if this opens the door to a home generator that powers it self . Your numbers indicate i was right >1  is an understatement : I respect you Analysis  and now welcome you to Join our team . Thank you for taking your time to explain these fascinating energy storage devices . They also work on Bedinis as both the run and the charge . Just swap and it tells all . If you made the Proper capture circuit . We are busy making a new coil to increase  or decrease charging time on a simple Jt . the effect can be increased by using a tip3055 transistor and a darlington . Also keep in mind that the Bcaps can be charged any number of ways ,solar ,jt ,bedeni , newman , what ever . I was already approached By unknowns who offered me a great amount of money to stop My e-light research . I refused . They know My address already . Black Helicopters regularly hover and buzz over My house .. Very loud and uncomfortable . this is why I went open source on this information so you guys can at least know how its possible and scalable .
Gadget
PaulLowrance
Hi cat,
Yes, the capacitance has so far increases at what I'd call an alarming rate with respect to even a slight temperature increase. What if you had a capacitor that was say 550F when you charged it, but was say 5500F when you discharged it?  ;) ;)   I'd call that excess energy.
Hi gadget,
Good to see you around. I agree there are probably a lot of ways to use these bcaps. It will be interesting to see how things go over the next month.
Paul
