Ultracaps tested for excess energy
Started by PaulLowrance, November 30, 2009, 12:47:01 PM
gadgetmall
MR Mh thisis for you bro . part one and part two . You cant explain this away can you ? IF you do then your the best !
part 1 http://www.youtube.com/watch?v=bLI0tDd7NnY
part 2 http://www.youtube.com/watch?v=oVmwc9OsyB0
Now i have heard voltage dont matter . well the reason this does what it does and here is a hint . I sacrificed a bit of light to make it self run . HMMM ?
Merry Christmas either way . I cannot hold anything against you as only know what you know . what you don't know bother's me though.NAd i did not get a chance to read  a post that you called me a scammer . well it was uncalled for and i am glad there is a mod here . You best replicate with your hand than your mouth ! I will never try to scam anyone . You might with disinformation but to slander me crossed the line big time . You should be ashamed Mh . Why do you hate the fact that I of all people have Ou and you are so smart that you don't? Jealous people make me sick .
Inspector Gadget
gadgetmall
Quote from: Cap-Z-ro on December 18, 2009, 04:38:57 PM
Personally, I fail to see where anything is to be gained by Gadget 'faking' the data on his self runner.
This seems to be confirmed by the circuit posted by jesus.
Gadget, my congrats seem to have been buried a number of pages back.
I always knew you had it in you...jesus also - you guys are bloodhounds.
Regards...
Well the Logic i have is to make sure everyone see's Ou . I have no reason to fake anything . I am not Mylow . I want people to do what i did . This is why i have tried to show how simple it really is to self run a project . It really is right in front of you guys . If i release My schematic of this elight what will that accomplish ? Nothing . I released the most simplest circuit in the world the JT charging a Bcap . What did i get for it ?  Negative remarks and grief . No one replicated it . Well Paul tried but i guess building 100's of jts i have learned somthing a newbe don't know . You know My focus is on low power circuits and i mean low input as possible with the highest output possible . Reason One is you can capture the excess energy not only in Bcaps but electrolytics and special diode configurations . I can tell you that this modified light began as a normal Jt  and not as My patent E-light using special  doped transistors . this one uses mpa 06  and three diodes and two electrolytic caps . Now if you build a jt with two secondaries and rectify one , rectify two and then rectify the EC junction you will have three voltages .. Go from there  ,, here is part two  and the outcome of what you can do with that configuration remember part one volts  . Another clue . I sacrificed some light for the run charger with another cap ,http://www.youtube.com/watch?v=oVmwc9OsyB0
gadgetmall
Quote from: Groundloop on December 18, 2009, 07:03:28 PM
All,
Today I played around with my JT and was testing the new battery capacitor I got
from Gadget. Thanks Gadget! :-) I soon discovered that this bcap will discharge at
a unbelievable rate if allowed to do so. I accidental shorted two wires and I have never
seen a transistor fly to the roof before. LOL
But that was not what I wanted to tell you. I wanted to try out regular batteries
since Gadget talked about using discharged normal alkaline batteries. I had a discharged
9 volt Duracell and it was down to 7,3 volt. I connected this battery and hooked a volt meter
to the battery connector. Then I watched the voltage slowly drop as the battery powered
the JT and lit up my single super bright LED.
Now, on this build I use a yellow Iron powder core with 2 x 12 turns and 1 x 44 turns.
I noticed that my out voltage through the Germanium diode was approx. 27 volt.
So I just connected the output wire to the plus of the battery. The voltage in the battery
did not drop so fast now. This was expected since we now have a feed back. Then I did a
mistake. I connected the Germanium output to one of the wires coming
from the 44 turn secondary output.
I noticed a jump in the battery voltage. I then connected my LED to the other end of the
44 turn and back to the collector of the transistor. You never guess what happened.
The voltage in the battery (it had go down to approx. 6 volt during test.) started to climb!!!!!!!!
It has climbed up to 7,8 volt now and has been running for more than an hour.
The ultra bright LED is lit to almost half brightness.
I do not expect the battery to last forever but I will run the circuit through the night and
check the voltage tomorrow.
The JT is a amazing little circuit. :-)
Alex.
This is exactly how i discovered what i did . By accident . Good job botching up a perfectly good no good for nothing jt and making free energy . darn .. now you will get flamed ;)
Albert
Groundloop
Albert,
My JT has been running for 12 hours now. The battery voltage has dropped to 7,67 Volt.
The ultra bright LED is still lighting at half the maximum (approx). Could you check your
emails? I have sent you a couple of mails.
Alex.
stprue
Quote from: gadgetmall on December 19, 2009, 04:21:54 AM
Inspector Gadget
That was awesome Gadget!  If that's not OU it must be closer then anyone else has got to unity!   :o
