Groundloop
All,
I have started a new thread over here:
http://www.overunity.com/index.php?topic=8597.new#new
Not offended, just a man of few words. :-)
Alex.
Pirate88179
Bruce_TPU
Quote from: mondrasek on January 06, 2010, 09:10:29 AM
Bruce, could you please check how well your ur 125 toroids attract to your permanent magnets?  I understand that as relative permeability decreases the attraction of a permanent magnet will also decrease at some point.  I am trying to learn how low the relative permeability of the toroid cores can be and still become fully magnetized and attracted to a neo.  Exact measurement would be difficult, especially since the geometry of the toroid plays a part and you probably do not have a toroid of steel with the same dimensions.  But your general observations are good enough for me now.  I would just like to hear if you think the attraction of a neo to your ur 125 cores is the same or less than the attraction to steel.
Thanks for your help,
M.
Hi Mondrasek,
I based my values on JLN labs.  The toroid he is using and is working well for him is .90" OD, wrapped with 39 feet of 26 awg wire.  His permeability is 120 and is Al is I think 87.  So, I got as close as I could to those values.  I tried to order his exact core, but could not find it here in the U.S.
Cheers,
Bruce
k4zep
Quote from: PaulLowrance on January 06, 2010, 11:09:52 AM
For me it's becoming rather clear who bedini is and what's been happening to the "free energy" community for decades. Very sad, but we'll win this battle! bedini's been playing his role for decades.
Now hold on there Cowboy, I have known John Bedini probably more than 15-18 years, had lots of conversations with him and he is a upfront man.  He doesn't write much but he sure walks the walk!
I too have had disagreements with him but always in a gentlemanly manner.  That he has patents on his devices and will defend them should be understood, but I have to say that I disagree with your tone and implications and will be first to vouch for him as a scientist, a builder and a Free Energy expert....That we have not cracked this nut of FE in the magnetic domain makes us all grit our teeth, but lets keep it on an even keel.  Sad?  without JB's work, probably we wouldn't even be here talking about Free Energy!
Lets stay on topic....and I know I am as guilt as any in rambling around at times....
Respectfully,
Ben
Larskro
As you can see. When the Buz71 goes ON. The volt over A---D is only 0,05 volt. A transistor has about 1,5 volt and 2 transistors pnp/npn have 3 volt. This give 3 volt losses. Not good.
A mosfet Buz 71 need over 4 volt on the gate to go ON. Therefor the lithium lipo cell. The current to the reed and the gate is only 0,007 mAmp. This losses means nothing. The Reed will hold for ever.
