Bruce_TPU
Quote from: Jimboot on January 10, 2010, 12:57:40 AM
Got the coil switch circuit working now. 0.3mm wire 100 turns
Jimboot,
Great!  Thank you, that helps a bunch!  I am using a different circuit to start, but will be trying several.
Cheers,
Bruce
captainpecan
@Gravity,
Nice work...  I'm a bit curious though, I can't quite make out the video that well, but is that a reed switch arcing that brightly?  Was this just a quick test run, and no recovery circuit yet?  Just curious, because if that is in fact the reed switch arcing so strong, unless you have got some extra to spare, I would modify that circuit pretty quick and extinguish that arc as much as possible!  Good work though, and those are some interesting anomolies you've got going on there.  Just don't overload your tv converter box on accident, or your GF won't let you build motors anymore, lol...
gravityblock
Quote from: captainpecan on January 10, 2010, 01:17:53 AM
@Gravity,
That is a homemade mechanical reed switch I made.  It probably cost 0.25 cents to make this switch and will last much longer than a normal reed switch.
I have no recovery circuit yet and I'm not really concerned at this moment about burning these cheap homemade switches out.  In fact it's been running for awhile now and the switch is just fine.  I will try Ossie's trigger coil down the road and work on the recovery circuit along with adding more toroid coils and optimizing the whole system.  Still a lot of work to be done here.
Here's a video I followed on making the homemade reed switch for pennies, http://www.youtube.com/watch?v=TC8-o1jm5Zo  I modified this process slightly to make it even more durable.
The arcing may be the cause of turning my webcam on/off and interfering with the digital off-air antenna, but it's really hard to believe because my off-air antenna is outside and a good distance from this motor.  I sure would like to know the exact cause of this.
[Edit:]  I can't believe how cool this coil is with the motor running.  It feels to the touch as if it wasn't even being used.  I can't detect any heat coming from it at all and it's been running continuously for about 15 minutes now.
GB
gotoluc
Quote from: captainpecan on January 10, 2010, 12:05:15 AM
@ Ossie, great stuff!  Looks like your drifting, but in a good way!
@ all,
A couple interesting things to note from Steorn's argument with TK:
1st...  When asked to replace the battery with a capacitor, Sean gave a response that made no sense... "Not as easy as you may think - we need a pretty instant current responce (due to the rotational speed), hence the 'deep' battery."
....  WTF, this makes no sense.  Why would he post a reply like that?  Everybody knows caps are WAY faster at pushing instant current than any battery I've ever heard of!  There are a trillion other responses he could have had to that question, but this was not a response I expected.
2nd... Check out this quote... "As for the delay - there is no delay, there is a current rise, its very slow, thats due to the core material that we use."
....  This would certainly indicate that they DO NOT use normal core material for their toroidal coils.
I'm more confused than ever about Orbo now.  I get the feeling that either Sean is just playing dumb, or they are trying to throw off any replicators.  Either way is fine, it's their discovery, and they are releasing it at their own speed.  It's just weird responses from Sean is all I'm saying.
Hi captainpecan,
I like the way you share your observations :)
I don't think Sean is trying to throw off replicators. As a matter a fact I found him to be very patient with TK and found TK to be a little had on Sean when he is trying to help before the official release.
Anyways, I think what Sean was trying to communicate to TK about the deep battery is I think at the time TK was running his Orbett on a depleted AA battery and we all know that a high Amp hour rated D cell will have much more instant amp delivery then a depleted AA battery. So don't expect to have Orbo results TK! .... what do you think of that possible explanation?
I think it's now also clear that the Orbo effect is based on many parameters to be very exact. Even they have a had time with it! so that goes to show that it's a delicate balance act.  So core material will be chosen for correct size, hysteresis and permeability to work with the chosen magnets, air gap, chosen space between magnets at operating RPM and I haven't even mentioned coil or switching characteristics.
If someone can achieve a working replication of the real Orbo effect before they release more information then that person deserves much credit for their accomplishment.
I'm not building a replication but more like Ossie slowly testing one parameter at a time to better understand what could be the Orbo effect before building.
If I find something worth sharing I'll post a video.
@Ossie, great experiment as usual mate ;D... thank you and everyone for sharing.
Luc
Jimboot
Quote from: captainpecan on January 10, 2010, 01:01:14 AM
Way to go Jimboot!  It feels good to get your first project running doesn't it!  Keep it up!
Thanks
@callanan 1st circuit with the reed switch was my fist working circuit.... ever   :) Ossie's detailed vids & diagrams made it easy for even a noob like me. I couldn't get the same transistors (pn100 & 200) so I used BC337 for the 100 & C32816 for the 200. Doesn't seem to go as fast as the reed circuit but I'm thinking that is the transistors.
