gravityblock
Quote from: Steorn
overconfident:  Since we have not seen a wiring diagram yet, can you tell us whether the coils are wired in series, parallel, or series parallel?
Steorn: Series - (and that is said in the video if you watch it) - but it really makes no difference.
@Bruce_TPU and All:
The quote from Steorn says it doesn't really make a difference if they're connected in series or not.
GB
i0n
Quote from: gravityblock on January 16, 2010, 09:51:53 PM
There is no reason to be done here.  You're post and information was very helpful and we all appreciate it, but the rescuing once again part and making everyone feel stupid because it was said in the videos isn't necessary.
Please continue to be helpful here in any way possible.  The more people involved the better off we are.  There is power in numbers.
GB
You see hidden attacks in my posts that aren't there. I never intended to belittle anyone's effort in here, nor did I mean literally rescue. It's a common phrase. I realize that me posting information that is available to everyone is not of much help, nor anything special.
I will however stop posting anyway as I'm honestly afraid you will take offense to something I say, which will lead to further arguments that won't help anybody. Don't take it personally.
So enough off topic now. Good luck guys in your replication efforts and keep solving the puzzle.
i0n
Quote from: gravityblock on January 16, 2010, 10:02:23 PM
@Bruce_TPU and All:
GB
One last input. I think he means it doesn't make a difference in the functioning of the device. It will work either in series or parallel. It does however make a difference in regard to the inductance. The full inductance is the sum of all coils, which means ~250mH does sound reasonable per coil.
PaulLowrance
People, something else I've mentioned that was ignored was that measuring the inductance of a core with such a high squareness factor can change significantly depending on the inductance meter. Even the slightest change in the AC signal from the meter can change the inductance. I went over this.
Bruce_TPU
Quote from: i0n on January 16, 2010, 10:10:27 PM
EXACTLY!
Our expensive cores are the wrong ones.  Incorrect inductance.  We need to source the correct cores, with 37 turns to come up with nearly 250mH...
So...Free energy is getting expensive...again...LOL  Can we please find the right cores this time... :D ;)
@ION
Keep helping, you've done well.  This thread is read by hundreds, don't worry about any one individual.
Cheers,
Bruce
