k4zep
PaulLowrance
Quote from: Jimboot on January 20, 2010, 07:18:12 AM
Not having any joy with a hall circuit. I've tried a UGN3503 running at 6V (not sure if I've done it right) but I've powered it separately to the rest of circuit running on 12V. The UGN3503 is only rated too 6V. The other hall sensor that I can get locally is not suitable for my rig. It is an ignition sensor. Based on @pl's circuit my mosfet gets hot (burnt my finger) There is V thru the coil. The coils get warm but my sensor does not seem to switch.
I recommended the UGN3130, not the UGN3503. My circuit works fine for me.
PaulLowrance
Quote from: PaulLowrance on January 20, 2010, 10:22:16 AM
Clarification: I did not "recommend" the UGN3130. That's what I am using, and it works for me.  :)
btw, can anyone show in a Steorn video that they are definitely measuring the voltage across the coil, or if that's the simply the signal to the relay. IMO, this idea that the pulse voltage must be flat is wrong. For efficiency purposes, I think their should be a constant current source during the pulse period. So during the first few dozen or so microseconds the current is rising in the coil, and therefore the impedance is high, but once the current stabilizes the only impedance is from the electrical wire resistance, and therefore ideally the voltage across the coil should be as low as possible when the current stabilizes.
Anyway, that's the way I see it. Magnetic materials react to electrical current, not voltage.
0c
Quote from: callanan on January 20, 2010, 08:47:36 AM
http://www.a.com/watch?v=oAw6p4BVfvs
Now it's time to take it to the next level. As well as ferromagnetic core material, the iron wire can conduct and generate electricity too. How much can be generated by it? And can it be done without moving parts?
http://www.overunity.com/index.php?topic=8597.msg222234#msg222234
0c
PaulLowrance
This is interesting. Yesterday I told TinselKoala about my over COP 1 measurements and videos, and almost immediately after he replied back with attacks, one of the moderators at this forum, Pirate88179, commented on my "tiny orbo replication" writing -->
Pirate88179 wrote at my youtube video page:
QuoteWhat drugs are you on?  You told a lot of people this would not work and to ignore it, and now....well, once again you seemed to have changed your mind.  you said B-caps were worthless, and now...you think they are the key.
I have *always* said Steorn & Orbo are legit! Also, bcaps have nothing to do with my video. And I never said bcaps are worthless.
Also, almost immediately after Pirate88179's youtube comment, I get a truck load of youtube negative ratings.  So, looks like we're all on to something here folks.  ;D   Keep up the good work, and lets help bring about global free energy.
Here's TinselKoala youtube message to me,
QuoteI am truly impressed, especially by your bogus measurements. If you can't convince them with bullshit, dazzle them with data, that works every time.
