callanan
Hi All,
Please see my latest video here.
http://www.youtube.com/watch?v=LJT_X_JfQcU
There has been an interesting development. As it turns out, I was able to completely remove and bypass all of the toroid coils! So there are no toroid coils in this motor. There are only normally wound air core coils in this motor. The motor now runs at 120 RPM and appear to even slightly increase in efficiency to the point of appearing to be 100% electrically? The battery voltage does not go down and the scope trace across the battery appears to show an even amount of energy both going in and coming out of the battery.
Please see the latest updated circuit diagram below.
Does this mean this motor is not a Steorn motor anymore? Does anyone know if Steorn's orbo theory could cover such this motor's operation in terms of still utilising their viscous magnetic theory in neo magnets? Or is it simply an amazingly efficient normal pulse motor?
Regards,
Ossie
callanan
Quote from: captainpecan on January 26, 2010, 01:00:29 AM
Very nice work, as usual!  Close to the speed expected, when you consider only half the amount of toroids as the original orbo, and 4 generator coils...  How long have you gotten it to run before you see any voltage drop in the battery?
A couple questions though, just so I understand the concept of what you are doing.  Why 2 reeds, wouldn't just one of the reeds do the same? Or is it so you can fine tune the pulse width more easily?  Also, why hook the generator coils directly in series with the toroid coils, and not seperate?  Are you using the generator coils to help drive your motor or something?  I am assuming that you have tried the generator coils in parallel and found the way you did it better or something, but I was just hoping to hear more on the theory behind why you hooked them up in this manner?  Also, where is your pulse in this setup?  Are you pulsing between 0 degrees and 30 degrees, or a shorter pulse width?
Great work though, keep it up!  Some interesting concepts and results.
Hi CP,
The motor has been running all day but the battery has NOT dropped even one millivolt. But please see my latest post for some interesting developments with this motor.
Two reeds allow far greater pulse width and timing control but also MUST be used to take advantage of the proper back emf to battery recovery I am employing in this circuit.
The generator coils in series is important to get the right voltage for the right RPMs that the battery needs to see. In this motor, yes the generator coils are also diring the rotor. Please see me latest video and post for further details.
The pulse is small and at the top peak of the induced generator coil's voltage.
Regards,
Ossie
penno64
Hi All
@GB - thanks for the circuit and description. I was trying to drive the input to the 555 from the hal effect sensor. Thanks.
@Ossie - Great work - I asked the question twice before, after viewing John Bedinis you tube and did not get a nibble from anyone. How I would love to replicate his effect of reducing the current to near zero by inserting the iron core. I have attempted a similar setup with pinball machine coils and my Hall effect and IRF540 and as a newbie, I was having trouble understanding what was causing the rotation. Any how, great leap forward and well done.
Kind Regards, Penno
captainpecan
Quote from: callanan on January 26, 2010, 03:23:06 AM
Wonderful results!  2 things I would love to see tested with your setup.  1. Could you replace that D cell with a rechargeable AAA with much lower mah rating, and see if it still holds!  2.  Use a cap of course instead of a battery all together.  Now I expect the cap will lose charge slowly, as they seem to be less efficient than a battery and a good piece of the added energy in these systems I think are related to the chemical effects in a battery, which caps obviously don't have.  But it would be interesting to see the results.
The biggest jaw dropper here is obviously the extremely low current draw!  It would be interesting to see what happens if you add an extra pickup coil or two!
wopwops
If Ozzie's torroidless system is using the Bedini effect/radiant energy, Bedini himself says that you can't use the same battery for driving and charging. It's in one of the Energy from the Vacuum videos. Does anyone remember that?
My point is that maybe it's not the Bedini effect.
