Bruce_TPU
Hi Larry,
Great job, really!  I have been scratching my head trying to get these blasted Magamps to saturate without needing a dozen amps with only 37 turns.  It did not work, not with my 1.12" Magamp anyway.
But I have now unwound one of my toroids, and rewound (1) One layer of 26 awg magnet wire, and shorted the leads.  Now, I will begin to wind one single layer of about 45 turns of 20 awg wire on top of that secondary.  And I am tweaking my switching circuit, with some help...LOL
Cheers,
Bruce
http://energyfreedomreport.com
Bruce_TPU
Primary is now wound over the secondary.  First completed toroid.
Cheers,
Bruce
maw2432
Bruce,   nice looking coil.  Did it saturate?    Could you please explain how you shorted the secondary?    Thanks.
I just received 4 of those toroids and was wondering how they should be wound.
Omnibus
Quote from: skcusitrah on February 07, 2010, 11:25:14 AM
Looks like [Steorn's measurement error] has been found.
You have given a link to an obviously incompetent commentary. Therefore, it is to be ignored.
