PaulLowrance
If we're going to use a BH-curve, then it would have to be the upper part of the BH curve, but even  that is not accurate for this setup. Consider the following two images. One image simply shows the full BH curve of the normal material just as a reference. The thin image shows the upper part of the BH curve, which you should use for the Orbo analysis, but again even that is inaccurate for the Orbo design due to the external field from the magnet.
PaulLowrance
Quote from: teslaalset on February 07, 2010, 05:17:48 PM
B.t.w. instead of a diode, it could simply be shortened as well.
(in case of reed switches or relais)
How would shorting it act as a rectifier? You mean short it a certain times? That wouldn't dump the energy back into the battery, as seen in the scope shot. From the start Sean said there was a diode placed across the coil, but if they want higher efficiency then they would simply direct that to the battery. As seen in close up camera shots of the board we can see a diode chip. These chips usually have 2 to 4 diodes, which is all we need to fully rectify the pickup coil.
The last Steorn Talks is very revealing. It shows the RL curve and time constant, and pulse width. The pickup coil scope shot provides some indication they're using a square loop core.  ;)   Also it shows how much of the energy goes back into the battery from inductance-- a high percentage.
Bruce_TPU
Quote from: Bruce_TPU on February 07, 2010, 04:57:47 PM
Hey Bill,
Ok, having a shorted winding on the primary does indeed allow the current to flow, and reduces the need for much voltage at all.  I have just burned up some wires (too much current), no biggie... LOL  But I now must switch from my 12 volt sealed lead acid to a D Cell and see what happens.  Worst case, I put it onto my power supply.  I really want to go with a battery if I can.
Shorted secondary (my green winding) is not connected to anything but itself (shorted)
Hey Bill,
D cell won't work for my setup.  I am using a Mosfet and it is not getting enough voltage to trigger.  But plenty of current!  LOL
For getting down to the bare minimum voltage needed and max current, it would seem that shorting the secondary is indeed the way to go.  But... My toroid STILL will not saturate.  (see pic below)  So I will add more winds in series with my 20 awg of 26 awg.  I have also ordered Jimboot and ossies toroid.
Keepin' windin'...
Bruce
http://www.energyfreedomreport.com
teslaalset
Quote from: PaulLowrance on February 07, 2010, 05:33:54 PM
Ah, I see some confusion occurring.
In my understanding the rectifier diode(s) were used for the pickup coil, not the driving coil.
I mean shortening the driving coil right after switching off the power to the driving coil. In this way one can switch off the coil at bit more earlier, because current is 'recycled' within the driving coil.
[edit]
In the scope picture the coil is powered until 25 degrees after TDC, while 45 degrees was mentioned as the optimum switch off moment in one of the Steorn videos. That would be a nice twist.
PaulLowrance
