gravityblock
This doesn't have CEMF or BEMF.  You can't capture the pulse because there is no BEMF.  The net gain in mechanical energy is more than the input energy.
This is a brilliant and nearly perfect system.  Have I said that before, lol.
BEP
Quote from: gravityblock on January 14, 2010, 06:05:45 AM
How to build an inexpensive Gauss-meter for under $6.00 using your voltmeter.  We will need this to match the dual magnets as closely as possible and to stay within 0.5T
http://www.coolmagnetman.com/magmeter.htm
GB
If you already have a clamp-on ammeter capable of DC just clamp the magnet in the 'bite' of the clamp and set the meter for DC amps. You'll find the Hall effect devices in those meters are calibrated. You can also buy such a meter for less than the price of a calibrated Hall effect device.
It won't read out in a magnetic value but this works great for comparisons.
BEP
Airstriker
Quote from: gravityblock on January 14, 2010, 07:59:38 AM
Why do you say that? Whether you got the gain in magnetic energy or not, when you release the applied current you've got a BEMF because of the colapsing magnetic field. Just as always.
At the colapsing time moment, the magnets are at the maximum distance from toroids. So there is nothing that would interfere the field colapsing.
gravityblock
Quote from: Airstriker on January 14, 2010, 08:24:10 AM
Because the flux remains fully engaged inside the metglas core during the collapsing field and never cuts the wires to generate a BEMF.
In a normal core material the flux dis-engages from inside the core during the collapsing field and cuts the wires and this induces a BEMF.
This is not your conventional motor.  This does not break any laws of physics, but the books will need to be re-written.  OU is real and possible.
[edit:]  If we could find a way to get the flux to dis-engage the metglas core during the collapsing field so it will cut the wires to induce a BEMF such as manipulating the end of the pulse, then this would be a huge bonus.  I highly doubt the Steorn camp has been able to do this yet.  It may be possible, but it would need to be manipulated somehow.
GB
Airstriker
Quote from: gravityblock on January 14, 2010, 08:42:35 AM
Wow now you really are rewritting books ;] If by applying current you are building magnetic field, then by destroying the field you "build" current ;] What's the difference what core material you use ? Don't try to change physics to understand ORBO ;] You people need some sleep ;]
