PaulLowrance
Steorn answers a question:
Quoteoverconfident:Does your "secret" core material demonstrate a significant Wiegand effect?
Sean: No
PaulLowrance
Another Sean quote,
Quote[snip] but as I keep saying this stuff does take a huge amount of precision positioning to get right.
adlep
Folks,
Sean is addressing a lot of questions about the eOrbo personally here:
http://www.steorn.com/forum/comments.php?DiscussionID=62495&page=1
Hopefully some of the comments will provide to be useful with replication attempts.
adlep
So to be honest, the whole ORBO is nothing special. I mean it's briliant, but it does not violate any laws. It just uses material properties and proper magnetic flux "redirecting" to spin the wheel with very little energy input. Then they just get more energy output than input, simply utilizing the kinetic energy they gained. That's it.
Ehm,
More energy output than input violates the law of conservation of energy, so even though your explanation is very logical, as a consequence we have a device that violates that rule...
Your explanation seems to point that they have found a way  to basically "shut off" the permanent magnet by redirecting its flux somehow...
Bruce_TPU
Hehehe!  I recall posting a photograph with some graphics, where I pointed out that the only difference between the "eorbo" motor and the pulse motor were the position of the coils.  The eorbo coil was on the "neutral line" between the N and S magnets as JLN Labs showed, produces NO CEMF.  Well, Sean has "verified" my find tonight.  ALSO, Stefan was correct in that the pulse motor coils were AIR COILS!  LOL
Goofy:  "So then in general, what are the physical differences between the two motors?"
SEAN:  "The only difference was the coils"
Cheers,   ;)
Bruce
Edit 1:
SEAN:  "Ok wobble in this arrangement will induce BEMF, full stop"
Technical Note to all, do not have a wobble in the rotor.
