futuristic
As I understood him he didn't disconnect the battery. So you can't talk about battery recovering here.
Frenky
PaulLowrance
Quote from: futuristic on February 03, 2010, 09:55:15 AM
Frenky
Sure I can because he did not even offer any details at all of his experiments except for one thing, and that was in previous experiments where he clearly said the battery voltage is slowly decreasing.
If he can dare to post that he did not disconnect the battery for the entire 43 hours, then I'll sit back and wait to see what his battery does next.  0.03 volts is extremely small, and could also be due to if the motor slows down, which draws less from the battery, which could easily cause 0.03 volts relaxation.
If jimboot is reading this, then all of this means that the battery cannot be disconnected at all during the 43 hours, and that includes while you're taking the voltage measurement. Disconnecting it for even a moment prior to taking the measurement can cause relaxation, and even relaxation oscillations that dampen out. Furthermore, that is by no means proper battery measurements! Again, *proper* battery measurements are taken when the battery has been disconnected and fully relaxed, which should be at least a few hours. That does not mean one cannot datalog battery voltage at all times, but the measurements one considers is when the battery has fully relaxed after being disconnected.
Please show the input & output measurements.
Airstriker
Staffman
Quote from: Airstriker on February 03, 2010, 10:17:28 AM
It's just me or http://www.steorn.com is gone ?
I think Domain Name Servers that Steorn is using is down.
NS79.WORLDNIC.COM        205.178.190.40
NS80.WORLDNIC.COM       205.178.144.40
I tried to ping both and getting timed out. I'm sure they will be back up after WorldNIC gets their stuff fixed.
EDIT: This could be a fiber outage as well. Doing a tracert, I'm getting stopped after...
Level3GigE.cybercon.com [63.208.32.186]
It should be up in a while. These things are sometimes quick fixes or horribly long (8 hours) outages. Yes I used to be in Telecom.
Steorn is back up at this time......
PaulLowrance
