LarryC
Quote from: Omnibus on June 19, 2010, 07:34:20 PM
Did you read that carefully, Larry? I guess not. So, I'll repeat it: in an RL circuit the power which is dissipated is only that due to the dissipative (Ohmic, active) resistance. that is, I^2R where R is the dissipative (Ohmic, active) resistance having nothing to do with inductance L. The part of the power delivered to the inductance is not dissipated. Again -- the part of the power delivered to the inductance is not dissipated when integrating over a full cycle. Can this come across to you or you need more explanation? Here in the discussion at hand we are only concerned with the dissipated power. Only the power dissipated is the output power (the power delivered to the inductance is not dissipated and therefore is not of interest to us in this discussion). Therefore, because the only dissipated power is I^2R where R is the dissipative (Ohmic, active) resistance having nothing to do with inductance or L, that's what we calculate as output power in our case. Get it?
Omnibus stated:
'Did you read that carefully, Larry? I guess not. So, I'll repeat it: in an RL circuit the power which is dissipated is only that due to the dissipative (Ohmic, active) resistance. that is, I^2R where R is the dissipative (Ohmic, active) resistance having nothing to do with inductance L.'
Larry states:
Yes, I did read carefully, but somehow what you say you read is totally different from the page that I posted. Total disinformation. Where did you get that statement from, you must be delusional? Can anyone here find what Omnibus stated in my page listing?
I've included the page listed again below to shows the actual original statement: 'In an RL Circuit, only a portion of the input power is dissipated. The part delivered to the inductance is returned to the source each time the magnetic field around the inductance collapes.'
Regards, Larry
IceStorm
LarryC , I admire your patience but i still think its a waste of time, Omni want to stick to his view even if we know that's not the correct one. At the end he will come to the same conclusion , will just take more time.
Best Regards,
IceStorm
Omnibus
Quote from: LarryC on June 19, 2010, 08:18:35 PM
Omnibus stated:
Larry states:
Regards, Larry
Of course. Do you understand what you just posted? Obviously not. Can't you understand that the power returned to the source is not dissipative power? Power delivered by the inductance and returned back to the source is not dissipative power. In this discussion we are only interested in dissipative power. Inductive power is not dissipative power. Only  power delivered to the active resistance (dissipative resistance, Ohmic resistance) is dissipative power. Only power causing Joule heating (Ohmic heating) is dissipative power. Only the power delivered to the active resistance, not to the inductance brings about Joule heating. Get it? Read first the scanned pages and try to understand them before posting them here.
Bruce_TPU
Hi Omnibus,
Thank you for the pictures of the primary, and of it rewound on your plastic bobbin.  Please humour me and give me a diameter measurement in millimeters...  Thank you!
Cheers,
Bruce
Omnibus
@Bruce_TPU,
That last coil is approx. 1.5cm in diameter and 1cm thick--425turns. I wonder what the awg of the wire is. You said 30awg which may be right. Will have to look around to see if I can order from somewhere similar or even thinner (if such exists at all). Also, you may try with the magnet wire from RadioShack. I'm playing right now with such. This is getting more and more interesting.
