7.8 Hertz Resonant Circuit
Started by braden, December 09, 2009, 11:41:47 AM
NickZ
   Perhaps, but it helps to know what you're aiming for, to hit the target. There have been endless theories, but no working devices.
   The thing is, to try and build up a device yourself first, then you can verify the results, of that mechanisms workings, or not working, as you thought.   Then we can discuss if there are electrons involved, or something else at work there. That's not an easy thing to prove though.
nix85
I wish everyone around here just focuses on few facts.
1. magnetic field is a source of infinite energy
2. if back emf is canceled,  we can multiply input energy proportionally to frequency of disturbance
now we come to antoher 2 key points.
1. stronger magnetic field can be produced by using thicker longer wire = same amps more turns
also by making poles as close as possible as in pancake coil, also bifilar (or even multifilar) config
2. making coil resonant will allow us to push energy more efficiently at desired frequency
Have in mind if you disturb the magnetic field "only" ~40,000 times a second it is an equivalent of single pole alternator spinning at ~2.4 MILLLION rpm, you get the picture.
Think and you will find.
Turbo
Quote from: nix85 on June 09, 2019, 11:20:38 PM
This is wrong.
I just wished the exact opposite.
That everybody would let go of the idea that a magnetic field is energy.
Magnetic fields are a property of space.
You are saying a light bulb is an infinite source of light, because you do not understand that it is the electricity that goes in that is making it shine.
That's primordial thinking.
We need to go beyond that and start using the underlying principles.
And it's about time, people have been running around magnets long enough.
forest
imho you are right in both cases but the essence is that magnetic field is a stream of peculiar waves which goes from "somewhere" into our 4-dimiension and back and it is pure energy but mostly in conservative way. That's why we need tricks to get energy from magnetic field...or use it in non-conservative mode. Tom Bearden said: don't kill the dipole
nix85
Quote from: Turbo on June 10, 2019, 04:06:08 AM
This is wrong.
You have no idea what you're talking about or you're a shill, in any case you shine like a brick.
Magnetic field is INDEED an infinite source of energy, first order effect of the Primary Light PRESSURE creating all lower manifestations.
