DIODES! Newman does not use his "special commutator" anymore
Started by kmarinas86, November 09, 2009, 04:19:12 PM
kmarinas86
Quote from: jadaro2600 on December 02, 2009, 12:47:49 AM
He also claims that hundred of fortune 500 companies bought his book..etc.
Honestly find the guy interesting, I wish his books weren't selling for 1200usd on ebay, I might buy one.  Too bad all his master prints were destroyed in a fire.
Or don't buy it.
Adobe PDF file:
http://www.megaupload.com/?d=5MF8ZFAJ
jadaro2600
seekingknowledge
Quote from: kmarinas86 on December 01, 2009, 09:01:38 AM
People.
It's just the way he talks.
Its funny you should say that actually, since reading this thread the other day ive been thinking again about an idea ive had but havnt tried yet of how newman has "transformed lightening to torque" i think it is easier then one may think, i have considered every idea possible on how he may of achieved this and like you said it is "just the way he talks", im a 100% with you on that one, just like when he talks and says he can turn his 7500lb machine "with a 9 volt transistor battery" well we all know he doesn’t mean using just one 9 volt battery he in actual fact uses several in series but he says he can do it "with a 9volt transistor battery" cos that is just the way he talks.
So how has he "transformed lightening to torque"?  mmmmm well lets just talk for a moment about his motor with the correct switching time that recharges its battery at an efficient rate, now forgetting about the fact that the spikes can kill the battery lets say that the back spikes are recovering 95% of the input energy back into the battery then if we wanted the battery to stay fully charged none stop we would only need to put in (from an external source) the 5% that is lost out of the system.
So i believe he has just replaced the battery with a capacitor which he openly shows in his later videos and uses an external source to keep the capacitor fully charged, that external source could be the solar panels or the grid, now lets just talk about how he uses the grid in some videos, well he has the motor connected to the capacitor and the capacitor connected to the grid (well actually through a transformer before the grid but forget that for a second) and instead of measuring input power between the capacitor and the motor he measures input power between the grid and the capacitor and so there for the volt/amp meters only show what is comming out of the grid into the capacitor not what is going from the capacitor into the motor.
So you see if we regard the grid as “the source” and the capacitor as “apart of the motor” and measure power from the grid into the motor then yes we can see a mechanical over unity of more than 100% but if we measure power between the capacitor and  the motor we will see less than 100% efficiency , there is one video where Joe unplugs  the motor from the grid and says  “look at how much power this thing makes all the time while its running” and even unplugged from the grid it continues to pump water for some time that is because it has charge in the capacitor and is putting charge into the capacitor while it continues to run, which seems like magic but however you unplug the motor from the capacitor then bang that motor will stop dead just like any other.
Now im a believer in Joe and im not trying to scream fake at all im actually saying what he is saying, somewhere on his website it is stated while a conversion efficiency  can never be more then a 100% a production efficiently can exceed 100% and more, well I think if you measure power input between the capacitor and the motor then you will see the conversion efficiency but if you measure power between the grid and the capacitor then you will see the production efficiency , the production efficiency is the one that counts.
I would like to elaborate more Kmarinas86 (and everyone else) but im hungry and tied , ive pretty much covered my theory on how “lightening is converted to torque” ( just the way he talks remember) if you need me to explain myself further I can plus an idea I have to raise the amps in the spikes, using diodes, anyway another time.
JustAnElectrician
Very cool, I'm sure I can get some good info out of this, it is similar to my so-called
Solid State non-rotary Newman device  ;D
Open Sourcerer Apprentice!
kmarinas86
Right now, I feel fortunate of the fact that I bought a multimeter that comes with a temperature probe.
And to think I was going to buy a seperate temperature probe!
I will take temperature measurements inside of the coil itself. Doing this will help me determine whether or not I am getting energy out of heat.
http://www.youtube.com/user/kmarinas86 December 30, 2009
THE ENERGY MACHINE OF JOSEPH NEWMAN
Various names for the device, in order of decreasing use:
1) Newman Motor
2) Newman Machine
3) Newman Generator
4) Newman Engine
Various parts necessary in a Newman motor:
1) Electrical energy source
2) Inductor
3) Rotor magnet
Various characteristics required in each part to obtain the type of operation specific to Newman motors:
1) Storage of electrical energy
2) High inductance coil
3) Magnetic
Various names for the energy source used, in order of decreasing credibility, importance, relevance, etc.
1) Heat (real)
2) Cold Current (estoeric)
3) Cold Electricity (poorly-defined umbrella term)
4) Vacuum Energy (misuse of mainstream terminology)
5) Zero-Point Energy (ditto)
Various forms of magnetism used:
1) Electromagnetism
2) Diamagnetism
3) Ferromagnetism
Role of the forms of magnetism:
1) Pass current through the coil
2) Extract heat at ambient
3) Convert potential to kinetic energy
Endothermic operation is the goal.
The Newman...
...shares the same source of energy as a Sterling engine
...can run off ambient heat provided the temperature of atoms drops below ambient temperature as a result of alignment
...has three stages of operation (excitation, alignment of magnetic moments at the scale of infrared wavelength - i.e. groups of atoms, mechanical output)
STAGE 1:
Excitation of the coils is achieved simply by turning on an electromagnet.
STAGE 2:
FACT: The energy of photons is acquired by the machine as potential energy.
QUESTION: Does the energy of the absorbed photons play a role?
YES: To restore a diamagnetic potential that is hardly ever used in the first place.
QUESTION: Is the diamagnetic potential rare? I've never heard of it.
NO: It is ubiquitous, but this magnetic potential field is almost never observed outside a diamagnetic material. The reason is that consumption of this potential energy is necessary to observe its effects macroscopically. Noticeable consumption is prevented by the presence of heat, the general exception being cases where there exists a very strong magnetic field. For example:
1) A giant external magnetic field to straighten the otherwise wandering magnetic potential of diamagnetic materials into straight lines. (A great example is the levitating frog experiment.)
2) A superconducting magnet.
The former case does not rely on removing heat. Rather it relies on strength of a magnetic field. A superconducting magnet does rely on removing heat to the extent necessary for superconductivity.
A THIRD WAY
Diamagnetism is most easily observed in the presence of very strong magnetic fields. However, it is hard to achieve the effect when there is visible distance from the material.
To achieve this within a material, all we need is a spark gap. This makes it more feasible to generate a strong magnetic response through the diamagnetic properties of the conductor.
In the Newman, a BEMF spike is used to produce a curl of the magnetic field around the wire. The atoms in the conductor's respond by aligning in opposite polarity to the back-EMF (Lenz's law). All atoms have a residual magnetic polarity. Theoretically, atoms lacking a crystalline structure (e.g. copper) are generally more responsive to back-EMF.
QUESTION: Can the net magnetic field curling around the wire be opposite the polarity of the magnetic field produced by the BEMF?
YES: When potential energy extracted from "atom alignment" exceeds the potential energy of the magnetic field of the backspike.
STAGE 3:
To allow utilization of the diamagnetic component of the magnetic potential energy, circular alignment of the magnetic moments of the diamagnetic material must be maintained throughout the time of extraction. This can be done through a combination of high magnetic circuit inductance and low electron flow density.
The extraction itself can be done using a permanent magnet as the rotor in the proximity of the electromagnet.
The output is eventually remitted as heat through inevitable friction.
JWN's machine:
http://video.google.com/vid...
IF the anomalous power (7.5HP minus 17 watts) comes from copper (200 lbs), this is equivalent to (7.5 horsepower - 17 watts) / (200 pounds) = 0.0374HP/lb!!! 27.88 watts per pound.
One pound of recycled copper sells for $1.2819, but copper in large motors can be cheap as "20 - 40 cents per lb". Each lb of Cu would collect 10 KwH of light, in 15 DAYS.
The type of electronic commutation seen in the Steven Mark TPU could easily bring this factor up several fold. However, less power density is necessary for preventing unstable temperature rise. There must be concessions....
