Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
darkspeed
Quote from: Groundloop link=topic=8586.msg220357#msg220357 =1262895319
Albert,
If two other people at this forum can confirm over unity in this system,
then I will make PCBs for this, else not. I guess I will wait for confirmation
of ou before spending money and time on this. I can add that my first
coil test gave me 14 Watt out with 38 Watt input. So there IS an effect
going on but if it is ou remains to see.
Alex.
Alex, what was your amps / volts for the 14 and 38 watts??
Thanks!
gadgetmall
I'm in . give me a bit of time to cut some pvc . I got plenty of wire in yesterday . This looks promising does it not ! . But i really wanted to use My pulse generator with a powersupply first to see if i can smoke some fet's  :) Its tubes so i'm not worried about smoking it .
Albert
Groundloop
@darkspeed,
Input was 12 volt 3 Ampere from lead acid battery via my RA switch.
The Ampere was measured over a non inductive 0,25 Ohm 20 Watt resistor.
The output load was a 15 Watt 230VAC light bulb. Did measure 12VAC
and 1,67 Ampere. The Ampere was measured via the same type resistor
and then used Oms law to calculate current.
Alex.
It's good to see more people are starting to become aware of this thread. If this is the real deal we might have the first replication before the end of the week. And kits very soon after, got to love the speed of the still "free" internet.
minde4000
I tried to feed 2500V pulsed DC into primary w/ spark gap then w/o spark gap w/ earth ground then w/o... 40W 120VAC bulb as a load stayed cold..
I would really like to see one in "action" on video with proper measurement techniques... (wich is struggling to materialize? makes me wonder why...) and not an LED screen of DC supply with is under inductive load... I hope I am wrong.
I will put it aside for now till someone else will have any luck with this.
Minde
