Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
teslaalset
@ Mannix,
Thanks.
I added another question while you answered my questions. Let me repeat that one: Do you have one or three primary coils?
teslaalset
Quote from: otto on January 12, 2010, 04:15:35 AM
YOU ARE ALL PULSATING THE WRONG COILS!! THE COLLECTORS ARE THE CONTROLS AND THE CONTROLS ARE THE COLLECTORS.
Otto, we communicate in different styles, I do not understand you.
Can you explain what you mean with pulsating the wrong coils?
I have 2 coils, a primary and a secondary. Pulsating the secondary is not what Tony does in my opinion.
Maybe you can visualize what you have in mind by posting a drawing?
agentgates
@teslaalset
Don't use your PG in pulse generator mode, use it in square wave generator mode and set it to a fix 50% duty cycle. 50% gives the best output signals (what you saw on my scopeshots).
33 ohms may give you lower input current than necessary. So if it's too low, please adjust it to lower resistance. With that coil configuration your input should be around 100mA 200mA if you want to see positive results. When you have completed the 3 coil drive it will rapidly fall below it.
IMPORTANT
I will write it multiple times again but I hope this time everybody will read it. :)
1. I noticed that many of you're trying to use PG instead of square wave generator. Expect the best results at 50% duty cycle. Below or above you will get worse results. (in some cases 10% adjustment may bring improvement, but don't vary it, leave it on fix 50%)
2. Frequency: no need to go to high frequency range. Stay in a FIX lower range (e.g. 100Hz or 1kHz). It is not a radio device.
@marco
The video you've posted is embarrasing but also extremely funny. All those coils have exactly the same problem and I am wondering if any of you were able to expect serious results.
When I cleaned up Stefan's I will also send you photos of my poorest devices with far better results and you're going to hit a hole in the wall with your head how simple they are. :)
Mannix
This thing surely pushes something like dc around in a circle, in one direction around the unit
If I take a single turn of copper pipe an hold it above the thing  and bring it down closer it triggers the cro
if i change the polarity of the probes, or turn the copper ring  upside down it does not.
A few more need to see this .. keep going gentlemen there's weird stuff here
agentgates
Quote from: Mannix on January 12, 2010, 08:43:05 AMThis thing surely pushes something like dc around in a circle, in one direction around the unit
Yes and if you put a load on it should not show significant drop on the peak voltage.
Lindsay did you save your previously opposite wound coils? If so, what do they show? Thanks :)
