Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
agentgates
Quote from: broli on January 12, 2010, 08:22:33 PM
Tony it's a bit confusing talking about phase degrees with square waves. I assume that 120 degrees out of phase means that the next pulse starts 1/3 of the on time later?
Yes broli you are also right. :) Some were confused by the 1/3 I said, so I will use both terms next time. ;)
Take care and good luck, I'll have a bath and nap now. :)
Many thanks for your help in advance. :)
Kind Regards
Tony
Magluvin
I was thinking the same broli
If one coil is on as the next turns on, it doesnt seem like it would affect the secondary due to there already being a field produced. But I can see the individual crossings separating that train of thought.
Well i measured the twizzler. The primary is 50 turns of hair wire at 8.32 ohms And the secondary is .02 ohm.
Taking the bemf off of a 0.8 ohm coil set up with a Big reed and a reed activator mag that closes the reed and the coil counters the mag and it oscillates. Using 5v nimh 4 AA. The capture is done by 2  22 mf caps off the osc. coil leads to a bridge. As the bemf dumps thru the 2 caps off each leg of the osc coil, that pulse on the other end of the caps enters the bridge like a pump, electrically isolated from the osc, which should give a large dc pulse at the other end of the bridge.
I put it to the primary of the twizzler coil.
I dont see anything on the secondary  AC or DC. But that is with a meter.
The twizzler is not THE coil so those results dont count as a negative test.
Will play a bit more, the I gota break out the 555 dog, and drops some fets on yo a$$.  Magrapp
Magluvin 0 7
otto
Hello all,
@Roberto
can you give me your mail adress??
Otto
otto
A all,
Im wondering why some particle accelerators look like the bottom of a open  TPU. Im talking about accelerators that are a few kilometers - miles in diameter!!
Its only from my memory because I saw the videos only 2 ot 3 times.
Again, please NO PMs because I can read them but NOT answer.
Otto
oscar
Hi,
those who thinks about the winding geometry of this device may want to consider this posting from energeticforum.com
http://www.energeticforum.com/renewable-energy/4587-marko-rodin-15.html#post77884
In his follow up postings user 'rococo' also supplied drawings of the different patterns. Unfortunately you can only see the drawings when you are logged into the forum.
Hope this is not too far off topic.
The transmission was a '53 (Johnny Cash)
