Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
Bruce_TPU
Looks good Spider!  I just wish you would have wound the primary with smaller mm wire, as Tony suggested.  Larger wire on secondary makes sense.
What diameter is your PVC form?
Kind regards,
Bruce
agentgates
@Spider
Very nice work! Give it pulse or wave and watch the output. It will be a nice dome and will be no RF noise. When you get the pulses/domes closer to each other the conception of the 3 primary coil version will be obvious. ;)
Keep on sending the results.
@Everyone
I am on the way with the 3-channeled driving circuitry with easy to buy devices. I don't want to use special parts. Also cutting the vids and keep documenting.
Spider
Diameter is 100 mm, higth 60 mm , wire is 0,8mm both.
Sorry Bruce, had no thinner wire laying around. :)
Maybe for the next one, takes just litle time to make these things.
Next one 350 mm diameter LOL ;)
Looking forward to your vids en pics Tony.
Spider
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
dani1
Hi Toni,
Congratulations, if it is all true. Don't forget to shield everyting properly. You do not know it it is emmiting anything.
dani
Mk1
@all
Did anyone tried 15 degree ?
The field cross at 90 degree , but at a angle of +/- 15 degree .
