Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
downunder
Quote from: gotoluc on January 09, 2010, 08:40:21 PM
Sorry Stefan but that is not correct!  I know, I use to work in multi standard video and Pal video is 23,976 frames/sec... it is Film that is 25 frames/sec world wide.
I've also experimented in uploading high quality files to Youtube and it comes to the same quality as my recommendation except for the fact of wasting much time uploading and huge bandwidth use.
Is there a lack of quality in my video's?
Try it for yourself and see if you can see a difference.
Luc
Hi gotoluc
I'm afraid Stefan is correct and you must be getting PAL and Film framerates confused.  Please check these links for confirmation.
http://en.wikipedia.org/wiki/PAL
"The majority of countries using PAL have television standards with 625 lines and 25 frames per second"
http://en.wikipedia.org/wiki/Frame_rate
"The 24p frame rate is also a noninterlaced format, and is now widely adopted by those planning on transferring a video signal to film. But film- and video-makers turn to 24p for the "cine"-look even if their productions are not going to be transferred to film, simply because of the "look" of the frame rate. When transferred to NTSC television, the rate is effectively slowed to 23.976 frame/s, and when transferred to PAL or SECAM it is sped up to 25 frame/s. 35 mm movie cameras use a standard exposure rate of 24 frames per second, though many cameras offer rates of 23.976 frame/s for NTSC television and 25 frame/s for PAL/SECAM. The 24 frame/s rate became the de facto standard for sound motion pictures in the mid-1920s."
ketone
I am making slits for the first of the three primary windings, by the time i make slits for the other two primaries, the spacing will end up around 2.5 mm between primaries? That is about as much as my big fingers can handle, Anyone getting closer spacing between primaries?
update: completed primary1...two more to go!
gotoluc
Quote from: downunder on January 09, 2010, 10:27:53 PM
Hi gotoluc
Yes downunder!  that is correct!... I knew that film was an even number of frames and 23.976 was a video frame rate and not film (motion pictures) in its original world standard frame rate. I guess that's what I was trying to get through. Thank you for clearing it up ;)
Sorry Stefan for the mix up.
Luc
Mk1
@all
I made one with a jt circuit 18 turns , with a secondary of 4 turns , i get 4.5 volt once rectified leds light on it , due to the design i made i get AC but if you really can get true DC from it i will.
Btw i used a 15/75 degree , 2n2222 transistor and 300 ohm pot , 1.5 v aa...
There is interesting stuff happening , i am surprised to even get anything from the secondary...
Mark
Super God
Quote from: ketone on January 09, 2010, 11:27:14 PM
WOW!  Nice coil!  Keep up the amazing work!
>9000
