Solid State Orbo System
gravityblock
Quote from: Airstriker on March 06, 2010, 05:09:28 PM
Brilliant post exnihiloest ! So actually no doubts that it's the magnet's field that's producing electricty in 2SGen (magnet interacting with the cylindrical coil). And the energy needed to make this flux leakage (Input energy that can partially by recycled) is equal to the energy needed to go from the MH curve's operating point (set by the magnet) to the MH curve's saturation point. What you will actually do by this energy pulse is only half core's saturation, but this is totally enough to release the magnet's flux. And this is shown by Naudin's Episode 8. But what I trully don't understand is why Naudin doesn't want to accept these facts ?
Maybe we're wrong - where ?
@GB
It's actually time loss to argue with you, so I won't. Say what you want - I don't care.
There is an unurled A-potential connected to the localized B-field that is confined inside the core.  This uncurled A-potential is present in the confinement zone and in the space outside it. In space, outside the B-field localization zone, there now appears an uncovered field-free magnetic vector potential A component that extends around the pickup coil.  So, all the B-field energy is still in the confinement zone, and outside it there is an additional curl-free A-potential energy. When we perturb the B-field in the localization zone, we also perturb the “inside” portion of that constant A-potential extending on out into space beyond the core and into the pickup coil.
We create a perturbation signal in that uncurled A-potential, traveling in all directions from its “beginning” inside the localization zone on out into its main body (energy reservoir) in the space outside and beyond. By localizing the curled A-component (localizing the B-field change component and holding it in a specific volume), then outside the localized B-field confinement area there appears an “uncovered” curl-free magnetic vector potential A. That represents a change to the EM energy density of the space-time outside the localization region, and so that outer space-time now has extra EM energy from which appreciable E-field energy will flow through the pickup coil and can be extracted easily by mere perturbation.
The energy extracted from outside the core will always flow in the same direction towards the core.  This is the very reason why the eOrbo motor will run in the same direction regardless of the polarity of the input pulse from the battery.
Perturbing a force-free potential or a force-free field in space does not involve force, power, or work. So the force-free perturbation can be work-free, generated by the perturbation of the input signal to the input coil.
In 1892, Lorentz arbitrarily symmetrized the Heaviside theory (a highly curtailed version of Maxwell’s theory) just to obtain simpler equations easier to solve algebraically, thus reducing the need for use of numerical methods. He thereby arbitrarily discarded all of nature’s asymmetrical Maxwellian systems, such as those producing the Aharonov-Bohm effect, the Berry phase, and the geometric phase. He also discarded (arbitrarily) all Maxwellian systems that can accept and use excess EM energy from the active vacuum, since any such system is an asymmetric Maxwellian system a priori.
This video is off-topic but the first minute of the video mentions how the powers that be, more than 150 years ago publicly funded the top scientific community while controlling and suppressing the truth (this supports the above paragraph and is the only reason a reference is being made to it), http://www.youtube.com/watch?v=zgmmCe1GGwg
Deceptions on a grand scale is still happening today.  The rabbit hole runs very deep. Don't allow the elitists to continue bamboozling and hood-winking us into deception and slavery.  Take off the blind-folds and see the truth.  The truth shall set you free (literally).
Don't continue to allow the facts to be twisted by the powers that be or anyone here on this forum.  This has been going on for way to long.  Let's put a stop to it, right now.  Naudin is on the right path.  There are those waiting for Steorn to disclose the fundamentals behind this technology, but they are overlooking how Naudin is disclosing it right before their eyes without taking notice.  I hope this post and what Naudin is doing, will burn each and every one of the dis-informants here, to the very core of their being.
GB
Mk1
@all
I started fiddling around so far i get the same output magnet or not.
gravityblock
Quote from: Airstriker on March 06, 2010, 09:42:38 PM
Whose theory is it this time ? I will not argue with that as I don't trully understand it. You should do the same if you don't understand mine.
In modern physics the magnetic vector potential A is absolutely required and well-known. Modern electrodynamics (such as quantum electrodynamics, gauge field theory, Yang-Mills theory, etc.) recognize the potentials as the primary realities, and the fields as just changes in the more primary potentials. Modern electromagnetic physics is not just a simple Lorentz-symmetrized classical EM concept! Instead, to deal with EM systems that are asymmetric and therefore permitted to extract and use excess EM energy from the active vacuum, one must have as general an appreciation as possible for the A-potential and its importance.
Thousands of theorists and experimentalists have verified the effects both experimentally and theoretically, and they are continuing to discover new related effects as well. Any person trained only in CEM/EE who proclaims that all these scientists and experiments are false â€" and that the A-potential and such effects do not even exist, or that vacuum engineering by EM methods is impossible â€" is still very much in denial and in the dark ages.
I've posted information on the uncurled A-Potential in the other thread way back.  I don't mention it much and I try to use other terminology instead in order to avoid negative feedback.  Actually, you can see a reference to it in every post I have made.  The reference is located right below the number of posts I have made.  It's been there for a long time.
People seem to fear what they don't know, so I try to use terminology they are familiar with so it's more likely accepted.  This also fails most of the time.  We are very close to the real deal.  I feel it.  This is very important to me.  I don't want our species to be enslaved by the powers that be; due to deception, suppression, etc.  This is the reason why I'm so serious about this.  If I appear to get upset from time to time, it's only because I care.  If I didn't care, then it wouldn't bother me.
GB
Bruce_TPU
Hello ALL,
I must be taking the resistance reading incorrectly...  :o
I clipped the resistor I have had across the leads, and placed 4 10mm LED's rated at 50ma each, 5 volts there.  The resistance reads 49.9 ohms
New Power Output   ???
V  20.88
R  49.9
I  0.41844
8.73709  WATTS   ???
Is my resistance reading wrong?
NEW FREQUENCY:  500 Hz   Duty Cycle:  64%
All I did was clip the resistor I have had on there since I was back at 4 volts, and put in some honker LED's.
Input:  .250 I, 12 V, 3 P(watts)
Not knowing what to think,
Bruce
gravityblock
Here's a good image of the uncurled A-Potential of a toroid.  The uncurled A potential actually fills the space around the toroid in all directions.  The EM pulses will flow from the space outside of the toroid into the core when the B-field is perturbed from inside due to it also perturbing the uncurled A-Potential outside of the core.
GB
