Solid State Orbo System
jaculat
hi I'm new here..
Have a look at my experiment :
http://www.youtube.com/watch?v=oXqL-HFw_xE
No measurements yet but looks promising...
exnihiloest
Quote from: void109 on March 14, 2010, 12:50:01 PM
I'm confused, I thought the leading conjecture that most in this and the other orbo thread agree on, is that pulsing the cores modifies the attractiveness that the permanent magnet experiences toward it.
Of course. Nevertheless it is a question of magnetic field.
As already said, "the attractiveness", supposedly a bit reduced when the magnet moves away, is not distinguishable by measurements from a leakage flux pushing it. Then there is no reason to imagine a new phenomenon when conventional physics gives the right answer to a conventional phenomenon (Okkham razor).
exnihiloest
Quote from: gravityblock on March 14, 2010, 02:16:20 PM
My point is, you can't say the magnets are vibrating in your experiment due to a leakage flux from the toroid being saturated until you rule out the other possibilities.
It is not to me to prove "other possibilities". You are reversing the burden of proof.
I showed that conventional physics and observations are in perfect agreement with one another. Then those who think it is neither a conventional phenomenon nor it can be explained with classical physics have to prove it.
When there are two explanations for the same phenomenon, the simpler is the right one. The simpler is one that doesn't need to rewrite the physics laws.
If physics laws do not work, where is the proof? Certainly not in a COP measurement that considers that R*I^^2 is only Joule losses, neglecting energy wasted in the underlying phenomenon of saturation.
Bruce_TPU
Quote from: jaculat on March 15, 2010, 07:33:06 AM
hi I'm new here..
Hi Jaculat,
Looks good.  Perhaps post a circuit.  My guess is that you are using a lot of power, even from the 9v bulb.  It can draw over 250 ma at 9 volts to light 3 LED's.
Take some power input measurments and use air gaps between mags and toroids and coils.  Should help lower your input and increase output.
jaculat
Mainly it's based on naudins generator with few modifications. Generator based on 555 with ability to adjust frequency and impulse. for powering lm317. On 9V battery its about 4,5 V on input but power measurement is with generator on same input so I need to separate it, to make it true.
I need to make output circuit to get full power to measure...
