Solid State Orbo System
jaculat
wings
I was trying it on my laptop and I've notice that square wave at hi freq doesn't look squarish at all and on mic you can measure up to 20kHz also amp is to low (up to 1V) so you need to amplify it (on gen) and on mic max voltage is +/-1,5 V. It depends of music card but not to much.
In my opinion ne555 is best solution price/capabilities
LarryC
[A author=Bruce_TPU link=topic=8597.msg234064#msg234064 date=1269377654]
Hi Synchro,
I think that I would have to agree with you.  It is certainly not the money, but putting it together...LOL   I have some gifts, but that is not one of them.  But I guess it will be good practice.  I wish they sold them already built.  It is a 40 piece kit, and is what I was hesitant about.   ;)
[/quote]
Bruce,
The Velleman kit has a Printed circuit board with each part displayed and parts presented  in order, which makes it extremely easy to assemble the 40 pieces. I'm sure with your demonstrated abilities it will be easy to build.
Regards, Larry
Bruce_TPU
Hi Larry,
Thank you for the words of confidence...  A rare thing sometimes on this forum.
I will buy it, and build it.  I am curious how SSG3 will respond.  I remain hopeful of success.
gyulasun
Hi Folks,
Here is an independently variable duty and frequency pulse gen from the 555 timer.  Use the CMOS type 555 like LMC555 or TLC555 to get as high as 2MHz output pulses and low power consumption.
rgds,  Gyula
Bruce_TPU
Quote from: gyulasun on March 23, 2010, 07:29:20 PM
Hi Folks,
rgds,  Gyula
Hi Gyula,
Wow, that is a simple circuit.  I ended up ordering that kit last night... LOL
I may build yours as well and compare the two.  I think if I have any hope of seeing OU in my SSG3, I will certainly need a low power consumption pulser.  Thank you for posting that.
Also, my L Meter arrived today!  Yea!  I will soon have some inductance readings for you.  I will need your help figuring out caps for resonance.  Thank you as always for your assistance.
Kind regards,
Bruce
EDIT:
Center Bias Coil Inductance = .959 mh
Capacitance is aprox 48.8 uF
All 5 brooks output coils together at the output in parallel = .60 H  (problem with top coil leads, long story)
Capacitance is aprox 41.2 uF
